Question about Dishwashers
I have a whirlpool model KuDSO1FL and the clean light blinks and won't start after the cycle has been selected and the start button is pressed. I have tried canceling the cycle but it won't work. The dishwasher was working yesterday and today it drained once we cancelled the cycle and then pressed start but that is all that we could get done. I don't know what the problem is.
  • majhnsn Jan 31, 2010
    Hi there, I don't have a high temperature wash button, etc on my panel. All the choices that I have in order for the cycles are Baked on Cookware, Normal, Light/China, Quick Clean-Up andRinse Only. The panel then goes into the Options which are in order, Hi-Temp Scrub, Sani-Rinse, Engery Saver Dry and 4 hour Delay. After that there are three areas where three lights can come on to indicate the control lock, the sanitized or clean. The clean light is the one that is blinking and won't stop. It is blinking 7 x before it pauses and starts blinking again. I have tried using my owner's manual to cancel the problem, but it doesn't work. Any other suggestions?
    Jan 31, 2010
    - Hi there,my whirlpool dishwasher model KUDSO1FL won't start. The clean light just keeps on blinking. I don't have a high temperature wash button, etc on my panel. All the choices that I have in order for the cycles are Baked on Cookware, Normal, Light/China, Quick Clean-Up and Rinse Only. The panel then goes into the Options which are in order, Hi-Temp Scrub, Sani-Rinse, Energy Saver Dry and 4 hour Delay. After that there are three areas where three lights can come on to indicate the control lock, the sanitized or clean. The clean light is the one that is blinking and won't stop. It is blinking 7 x before it pauses and starts blinking again. I have tried using my owner's manual to cancel the problem, but it doesn't work. Any other suggestions?
  • 2,926 Answers
Your appliance's clean light blinking will require a service call. It could be several things indicating a problem that are not serviceable by the home owner. You can try turning the power off at the breaker box, then turn it back on and see if this resets the blinking light.
Posted on Jan 31, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    As I said earlier press to resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...high temp scrub then energy saver dry then high temp scrub and then energy saver dry. If this does not resolve the issue then you have to get the control board replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool model KUDSO1FL not starting cleaning
I fixed the problem by hitting Hi-Scrub then Economy Dry in sequence four times in a row. All of the lights came on, I am assuming to reset it the program, then went off and the start button was highlighted. I then pressed cancel and then selected the program that I wanted to wash with and pressed start. It worked like a charm.
Jan 31, 2010 | Whirlpool Dishwashers
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
115 people viewed this question
Top Dishwashers Experts
Owen Barnes
