Question about Bosch Ovens
I have an HBN 13N5.OB double oven that wont turn off the cooling fan or the main oven light.
4 Suggested Answers
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
espressonist
  • 1711 Answers
SOURCE: I need to replace the
We have here below two videos that can help you to replace the oven fan. Maybe there will be some diferences in your model but these videos is the best solution to your case
http://www.youtube.com/watch?v=6QGurNvbI0Q&feature=channel
http://www.youtube.com/watch?v=pEhRqdvpiJM&feature=channel
Posted on Nov 07, 2010
  • 88 Answers
SOURCE: I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN
Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
*** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
Posted on Nov 14, 2010
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
Nov 14, 2010 | Bosch Ovens
Main oven doesn't heat up. is there a fuse i can change some where?
If it is a electric fan assisted oven, and the fan is working o/k, then you will probably find that the oven element is faulty.
This is located at the rear of the the oven compartment, behind a removeable cover.
Hope this helps.
Dec 31, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bottom oven does not heat up fan works
The element is usually located at the rear of the oven compartment,behind a removeable cover, this is also where the fan is located.
Hope this helps.
Nov 29, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Oven will not heat?
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
Ovens Logo
123 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
