Question about Kenmore 23822 Top Load Washer
Washer will not drain it is a kenmore top load all it will do is fill
  • 4 Answers
Some of these washers have a electric drain pump. I had a Maytag MAH 3000 front load washer. I had the same problem. Find out by the model number.If it does. Put the washer in drain mode and check the voltage on the wires to the pump.The wires should have line voltage. If it not electric, but mechanical which it has to be operated by some other source, like driven by the main motor.
Posted on Feb 08, 2010
  • 135 Answers
You might check the switch on the lid. If that goes bad it will still fill but that is it.
Posted on Jan 31, 2010
  • 49 Answers
Most likely you have a broken drive coupler. not recommended to repair yourself
4 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore washer...the water just runs it never fills up.
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
Kenmore 90 Series Heavy Duty Top Load Washer Model 110.28922790 water fills in tub and it's draining at the same time. Won't go through the normal cycle just keeps filling and draining. Any help...
You may have a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 17, 2010 | Kenmore 22442 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer fills and spins at the same time
If the washer has been recently moved the drain hose may be too far down the stand pipe causing a siphoning effect
Jun 11, 2008 | Tecnik TKL9260 Front Load Washer
Kenmore top load (model # 110 82370120) drain problem
Could you please rephrase the question. I'm not sure if I'm understanding this correctly
Dec 01, 2007 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
Did u clean out your outlet filter. If u did..... Go to 'troubleshooting' above, click on page 2, look for 'replacing lid switch' Generic Problem. Catriver is pretty good.
Feb 17, 2007 | Kenmore 24872 Top Load Washer
Kenmore 23822 Top Load Washer Logo
88 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
