Question about Whirlpool GS5SHAXN Side by Side Refrigerator
The Freezer and refrigerator stopped cooling. The fan blows but only warm air is coming out.
  • 49 Answers
Might be the compressor,compressor relay or overload or the sealed system may have a leak. call an appliance repair company. not recommended to repair yourself
Posted on Jan 31, 2010
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Our arctic air freezer blinks "csd" alarm code.
Can you look to see if the fan below your refrigerator is blowing a strong steady flow of warm air. Sounds like you either have a fan problem or an obstruction blocking air flow to the condenser. This will cause the refrigerator to stop cooling. What is the model number? Thanks Sea Breeze
Sep 02, 2013 | Refrigerators
MTB2156GEQ
is there air coming out of the freezer vent inside the freezer? If not, then there is ice built up on the fan. Let me know if there is air blowing in the freezer or not.
Jun 09, 2012 | Maytag MTB2156G Top Freezer Refrigerator
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Fan in freezer runs and is cold. No air is coming
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
My amana abd2533dew purchased in 2005 has stopped cooling.Woke up with the freezer blowing warm air,all food thawed. refrigerator temp falling fast.Service can't come for 3 days? I have an extended...
If the freezer compartment is blowing warm air, then you either have a problem with the compressor (or a freon leak) or a problem with the fan located next to the compressor (at the back of the machine).
Attached to the compressor is an overload protector, which is most likely what broke, but if you are covered by a service contract your best bet is to wait it out and let them fix it. One thing that might have caused the overload to break is too much dust on the condenser (the radiator looking thing underneath the machine, accessible from the front).
Jan 01, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Refrigerator and freezer are not cool enough. Cleaned coils,has enough space between walls.etc.
Most likely problem is the internal fan. The fan draws air across the cooling coils and blows it into the freezer and refrigerator compartments. If it malfunctions, there's nothing to move the cold air and both sides of the unit get warm.
Nov 20, 2009 | Whirlpool ET1FHTXM Top Freezer...
Refridgerator with bottom freezer. Fridge is not cooling at all, but bottom freezer is just fine. What do I do
With almost all refrigerators, all the cooling takes place in the freezer and a fan then blows some of the cooled air into the refrigerator section to cool it. Look for a non functioning fan in the freezer, frost or ice build up in air ducts leading from freezer into refrig section, and make sure controls are not set to the coldest freezer setting. (that keeps most of the cold air in the freezer)
Sep 01, 2008 | Maytag Refrigerators
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
