Question about Ricoh CL4000DN Laser Printer
Printer problem Printer prints only one page no matter how many I send
  • Sargie807 May 20, 2008
    Pinging my Richoh CL4000DN fine for 1 minute then goes to Request not reponding. Turn off the printer then back on ping resume fine for 1 minute then stops. What am I missing in the confirguration?
Printer is connected to a CISCO switch which uses DHCP to hand out IPs. There is no server at the loction were the printer is located. Printer is set up as a local printer to the workstations via IP addressing.
Changed the speed from 100 to 10. Pinging last 10 minute instead of 1 minute.
Had the tech take it back to their systems were they were successful in having it connected to a switch that was DHCP and it work fine.
Possible problem with CISCO????
Posted on Aug 14, 2008
  • 87 Answers
Uncheck collate in the print properties.
Posted on Feb 23, 2008
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How do I tell the printer to take from the top tray?
Page 63 of your HP LaserJet 4600dn printer manual:
Controlling print jobs: (condensed version) MS Windows
Three settings affect how the printer driver tries to pull paper when you send a print job. The "Source," "Type," and "Size" settings appear in the Page Setup, Print, or Print Properties dialog boxes in most software programs.
Your question indicates that you wish to configure your printer to take from the top tray. That is a "Source" setting. So in the print Setup or Print Properties dialog box, change the "Source" to Tray 1.
Printing by Source means you choose a specific tray
from which you want the printer to pull paper. The printer tries to print from this tray, no matter what type or size is loaded in it. If you choose a tray that is configured from the embedded Web server for a type or size that does not match your print job, the
printer does not print automatically. Instead, it waits for you to load the tray you chose with the type or size of print media for your print job. If you load the tray, the printer begins printing. If you press the printer tries to print from another tray that has the correct type or size.
Kindly vote for my solution if this info was helpful.
Dec 30, 2009 | HP LaserJet 4600dn Color Printer
How to set a printer to print only 1 copy no matter what # is put
You cannot do it -- when you request '3' copies, the computer sends 3 times as much text & commands to the printer. So, the printer cannot tell when the 2nd and 3rd copy begins.
Sep 14, 2009 | HP LaserJet 1200 Printer
Our printer (Kodak 5300 AiO) won't print pictures no matter what program we print them from. All we get is a few colored lines across the page. What should we be doing?
Follow the trouble shooting guide lines that came with your printer. I had the same problem and followed those procedures and then contacted Kodak with the info. It turns out that the printer head is bad and They WILL send You 1 FREE of charge and a free color and black cartrige along with it. The print head just snaps out and the new one snaps back in and You send it back in the prestamped envelope. the Printer parts are guaranteed for LIFE and are free if You follow the guidelines in the trouble shoot area.
Hope This Helps:
Aug 21, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not accept the paper no matter what i do. i need to know how to take the printer apart. its a lexmark x85 all in one.
Please, do not take anything apart just yet.
Are you saying that regardless of where you insert the paper, no paper is fed into the printer when a print job is sent to the printer?
If you are, then you need to install the paper in one location, then make sure your driver properties is set for that location. Once that is done, then you need to go to page setup in the application you are using and make sure you are sending the print job to the same paper source.
Also, try using the printer all alone. Don't connect it to the PC. Go into the maintenance menus and print either a test page or a demo page.
If all else fails, do a "Print to file" from the driver. Then when prompted, name the file "papfeed". Send the job to janddgasrepair@verizon.net and I'll see if I can read the file and tell where it is expecting the paper to come from (no charge)
Don
Jun 10, 2009 | Lexmark C533DN InkJet Printer
Printer prints garbage, no matter what I print
I suppose you may have an uncleared printer memory. Right your printer icon and select Open from the shortcut menu. click on document menu and highlighting all the pending files select Cancel to get rid of them. You may have power down the printer to fasten the process. It will take a couple of minutes and sometimes the pc will have to restarted to complete the process. Make sure the all the files are deleted before sending to the printer ok. Also check your printer very well, it could be it has a reset button. if it does, power it on and depress the reset button and that will settle the matter. If it doesn't, then you will have go for confirmed USB cable and adapter. Good luck
Jun 03, 2009 | Office Equipment & Supplies
Printing is faded after replacing both inks. Have the same problem with my Lexmark printer!!!
its true it is not the year that matter but you make use of the machine that matters
May 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to do a reverse form feed in Visual Basic 6
Two things to consider:
1) The printer itself must be designed to handle reverse form feeds. I am not sure how many these days are.
2) If you're printer can handle reverse form feeds then it should be a simple matter to send the appropriate ascii code to the printer to initiate it. Much the same as if you wanted to have the printer do a line feed.
Good luck and thanks for using FixYa.
Mar 18, 2009 | Microsoft Visual Basic 6.0 for PC
Printer only prints half a page
I have a Lexmark 5400 series printer that is only printing the top half of a page. Any suggestions anyone ?.
Jan 20, 2008 | Dell A920 InkJet Printer
Ricoh CL4000DN Laser Printer Logo
142 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
