Question about Aurora Electronics AS662C Shredder
The motor on my shredder will only run in reverse
    President:
  • 2,306 Answers
You need to remove the top section, make sure it's unplugged, and use a tweezers or very narrow needlenose pliers, and pluck out any paper chunks, and use canned air to blow out the paper dust. Reverse only means the chopper thinks there is paper jammed inside and will only run in reverse to clear the jam.
Posted on Jan 31, 2010
My shredder says it will shred cd's and dvd's but when I tried, a cd went in 1/2 way and now is stuck. Motor runs but nothing happens in forward or reverse
You can turn the shredder over (after unplugging the power cord) and see if you can pull the pieces out from under side.
Sometimes the motor gear teeth break off, and the motor just spins but wont go forward or reverse.
Hope this helps.
Feb 25, 2015 | Shredder Office Equipment & Supplies
Why does my intimus 602 shredder only run in reverse
This applies if Reverse is forward, and forward is running in reverse. If someone worked on it they may have reversed the wires from the motor to the board. There are four wires from the motor, of the four one goes to MZ on the board, another one goes to MV. If you swap these two wires you will be running in the correct direction again.
Aug 14, 2014 | Intimus 602 SC Shredder
My ativa hs 2000 paper shredder will only run in reverse
If the motor will only run in reverse and, you are stating that all the buttons are working. then most likely, internally the motor has burned out try tapping the motor lightly with a small hammer while the shredder is plugged in and on in the forward position. if the motor begins to move it will lead you to the answer of a shorted out internally motor.
Oct 15, 2012 | Office Equipment & Supplies
When I try to feed a piece of paper into the shredder, the overload light comes on and the motor stops running. It will run in reverse. Oh and when the overload light comes on, the pull out basket is...
You say it runs in reverse...does it seem to run slowly??? Have you ever "oiled" the machine.???
This is a x-cut shredder and must be oiled...get some "shredder oil " and try pouring some of the oil across the cutting blades and running the machine in reverse. See if it seems to pick-up some speed after the oil in tried. Then see if it will run in the fwd direction for you.
Dec 07, 2010 | Royal VF1012mx Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Shredder motor will run in reverse, but not
Sounds like a bad or dirty switch you can try to clean it with alcohol ( the switch that gets activated by the paper)
-Carl
Jul 06, 2009 | Fellowes Powershred 480 Shredder
Only runs in reverse
please post brand and model
Jan 05, 2008 | Royal 1280MX Shredder
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Aurora Electronics AS662C Shredder Logo
456 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
