Question about Kenmore 24 in. 16032 Built-in Dishwasher
Green light on clean cycle is blinking seven times - cannot reprogram it
  • 49 Answers
This usually means the chopper blade is broken or the sump screen is plugged. you will need to disassemble the sump to check
Posted on Jan 31, 2010
Clean light blinks seven times and will not start on any cycle.
The problem you are having is that the dishwasher is sensing that the water is not getting hot enough to finsh out the cycle. The first thing you need to do is get the dishwasher into diagnostic test mode, you can do this by pressing: normal wash then heated dry, 4 times. After in diagnostic mode you can exit out by pressing cancel/drain. This will get rid of the blinking clean light and the washer can be operated in any cycle now. To prevent this light from coming back on, you can do one of two things. First you can just try running Hot water at the faucet before each time you use the dishwasher. Or, you can replace the thermistor/sensor that senses the water temperature. You can purchase this part at this link http://www.repairclinic.com/Sensor-Or-Thermistor-Parts?s=t-DU1055XTS-%3d%3dc61
Nov 27, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Kenmore DW blinking clean light 7 times, pausing, blinking 7
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Oct 11, 2009 | Dishwashers
RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
Error lights
Dear mary,
Blinking in Orange/Green or jus Orange is one of error indicator of canon inkjet printer. You need to specify how many times it blinks to get more help. Find how to identify error indicator here. Read more article there and you will get what I mean.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Gives the error for ink tank full
Before you try to reset your Canon i9100 be sure to remove the ink head itself before attempting and then replace after, it won't work if you don't, I almost threw away 2 good printers before I read this today.
Jan 24, 2008 | Canon i9100 InkJet Photo Printer
A bank of blinking leds??
The blinking LEDs means it need to have it's ID reprogrammed. Press the Program button and then the station number (Station 1 or 2 or 3 etc) to store the setting.
Nov 14, 2007 | Panasonic KX T3281W Corded Phone...
Kenmore 24 in. 16032 Built-in Dishwasher Logo
131 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
