Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Replace the oil pump in a Echo CS4400 Chain Saw
    President:
  • 2,220 Answers
An IPL for a CS4400 Chainsaw can be found here (there are multiple IPLs, please ensure this is your saw):
EchoUSA
http://www.echo-usa.com/documentation.asp?Model=cs4400&lang=E
There is no sigle illustration of all oiler components, they appear on multiple illustrations.
From the IPL it has an outboard clutch, it appears the oil pump is behind it. Use this a guide for clutch removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
You can reply below with any questions if you need additional help. I hope you found this most helpful.
Lou
Posted on Jan 31, 2010
How do you locate, repair or replace the oil pump in Stihl chain saw
Most oil pumps are located behind the chain clutch drive.
Jan 26, 2015 | Garden
Oil will not come out for bar chain
check the oil pump behind the clutch make sure saw dust didn't plug the output
Aug 09, 2012 | Echo CS400 18" Chain Saw
Oil wont come out for bar chain
the oil pump is behind the clutch they can get plugged with dirt or saw dust
Leaks chain oil when not in use
two things come to mind. 1. The oil adjustment screw on the bottom of the saw is set too high for the type of cutting you're doing.
2.If the oil setting is too high, your saw will have an excess residue of oil on the , chain, sprocket, and oiler. When you set the saw down Oil runs out. Try setting the oil adjustment screw back a turn. Find the screw on the bottom of the saw., or check the owners manual. Good Luck! Alvin
Aug 31, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Chain is not getting oil
Remove the bar and chain--clean the port area where the bar fits. Run the saw at speed for a few moments--it should ooze oil out of the port. If it doesn't, then you need to check the pump, lines, and tank for plugging or other problems. If the oil came out ok, then clean the bar drive-end small oil passages that run out to the chain groove on each side. Clean the entire chain groove as well. Reassemble the bar and chain (the teeth cut toward you on the lower run), and adjust the chain so that it just pulls up to the bar, but not so tight that you can't pull it by hand. Run the saw tip at speed near some cardboard--it should throw off a thin line of oil. Hope this helps!
Jul 09, 2010 | Echo CS400 18" Chain Saw
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I fix firing problem on my ECHO CS4400 chain saw
You will need to dissasemble the unit and clean the flywheel sensing unit with sandpaper. also clean the magnet on the flywheel.:)
Sep 07, 2009 | Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
901 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
