Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
What is the recommended temperature for the 14 cubic foot upright freezer?
    Problem Solver:
  • 7 Answers
At least 0 degrees
Posted on Feb 03, 2010
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
Will 3.74cu.ft. freezer hold 95lb of food?
Hi Trish:
1 cubic foot of water weighs 62.4 pounds so if you had 3.74 cubic feet of water (not frozen) it would weigh just over 233 pounds.
Most of the frozen veggies you put in a freezer have air space and the specific gravity (weight per cubic foot) is quite a bit less than water. Meats are closer to the same weight per cubic foot as water, but you still have air spaces between the packages.
I'd guess that you could get 95 lbs of food in it but you would have to pack it very carefully.
May 18, 2015 | Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Jul 12, 2014 | Frigidaire Freezer Refrigeration White...
What is the on/off switch at the bottom for.
Sorry to read about your problem, I hope this helps you out.
High-Temp Alarm Switch (on some models)
An alarm will sound if the freezer temperature reaches unsafe levels. The alarm operates on household electricity. If the power fails, the alarm will not perform.
An ON/OFF switch allows the temperature alarm to be deactivated if desired. The freezer is shipped with the switch in the OFF position. After the freezer has run long enough to lower the temperature, you may set the switch to the ON position.
CAUTION: Adding more than 3 pounds (1.5 kg) of warm food per cubic foot of freezer capacity can trigger the alarm.
To activate the alarm, set the switch to the ON position.
To deactivate the alarm, set the switch to the OFF position.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | GE 20.3 cu. ft. / 575 liter Upright...
Need Freezer gasket for 20 cubic foot freezer upright Model #WFF20Z
I would suggest you check with a local appliance parts warehouse. They will also have a service manual that you can purchase that will guide you.
Sep 17, 2010 | Woods Upright Freezer V1613RW3
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
131 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
