Question about Kenwood KDC-MP235 CD Player
Cd player is not working
It is showing on display ''protect'', cann't do anything
    President:
  • 2,992 Answers
The unit is telling you it's shut off output because of some problem. There night be something wrong with one of your speakers or the wiring. A speaker may have shorted or a wire may be contacting a sharp edge somewhere and shorting to the car frame. This could also be due to a problem in the amplifier itself. Try unplugging the speaker wiring from the unit and see if it clears up. If so you can start isolating which speaker or wire run is bad. If the unit is still in protect without the load, you'll need to have it serviced.
Posted on Jan 31, 2010
My cd player is just showing PROTECT and not working??any ideas please
I would need more information such as the manufacturer and model number, I assume it's a DAF 44 but who makes that? In GENERAL
If PROTECT or PROTECTOR is flashing in the display of an audio device such as an A/V receiver, or home theater system (hts), there may be an external speaker issue or connection issue that is triggering the protection circuit
Jan 29, 2015 | DAF 44 Cars & Trucks
Why does the Samsung Home Theater DVD player display the word PROTECT then does not work?
if the speaker connections are not properly or anything wrong in dvd drive it goes in protection mode.remove all the speakers and insert the cd and see if it works with headphones. if it works check all the speakers one by one
Jun 04, 2010 | Samsung HT-DB120 System
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Help
HI SOUNDS LIKE THE RIBBON/FLEXI CABLE
try www.carradiospares.co.uk
Regards
Mark
Jul 31, 2008 | Sony CDX-M800 CD Player
Display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
Mar 19, 2008 | Kenwood KDC-MP5032 - Car Audio CD MP3...
My audio system says protect on display
Hi Jean,
Without a brand and a model, best that I can provide are generic possibilities:
1. unplug the unit from the mains for a couple of hours. This is supposedly to reset most systems; and/or
2. check the speaker wires and make sure none of any bare wires are touching each other.
If your concern has not been corrected after completion of the above procedures, pls post back brand and model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Audio Players & Recorders
Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Jul 23, 2007 | Kenwood KDC-MP205 CD Player
Kenwood KDC-MP235 CD Player Logo
117 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
