Panasonic NN-H275 Microwave Oven Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need wiring diag. for Panasonic H264wf - Panasonic NN-H275 Microwave Oven
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Jan 31, 2010
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340157
Points
4062
This site has it. Just do a search on your model number at www.devicemanuals.com
hardrocko
Panasonic NN-SN960S, turntable won't stop spinning. Have to unplug after every use. What kind of repair does it need and how much would it cost?
May be a door switch problem, or may be a control board problem. You might even have a shorted wire that goes to the turntable motor. (I have seen 1 of the wires get pinched and cut by metal guards or guides that were meant to keep the wires in place.) You can remove the screws from the bottom of the microwave oven, and drop the bottom panel down to checked for pinched wires. Unplug the microwave first before you do that.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
My light won't turn on and it isn't the bulbs being burnt out
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
That would be a problem on your controller assembly, which I can repair for $54.95, which includes insured return US shipping.
I would need to know the full model number from the tag on it, and the FCC ID number can be helpful, too.
Please contact me directly for full details since FIxYa doesn't always inform us of follow-up questions.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
My panasonic will run for about six seconds and stops, and smells like burning wires and it shows a message "SENSOR RE-HEAT PRESS START"
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor. But I don't think that's the issue here.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
2answers
Jenn-Air Microwave Oven (JMC8130DDB) is dead. CB in Main (Box) is OK. Microwave is mounted in a wall cabinet over a Jenn-Air electric self clean Oven. Oven was in "self-clean" when the Microwave...
Hi!
I read your comment about needing to remove the control board to inspect it for damage. Looking at the diag. below, all you need to do is open the oven door and remove the two screws (#2 on diag.) fastening the brackets that hold the board in place and you can take it from there.
Refer to the diag. below If it was me, I would start by turning the breakers for both ovens OFF, then, in getting someone to help me pull the oven out, disconnect the power cord and check the power circuit protection devices like the fuse #4, located above the fan and the power board #25 also located on the back of the unit. Before replacing the blown fuse, inspect the wiring, If the unit is mounted over an oven that was in the Self Cleaning Mode that reaches temps. of about 500 degrees, there is a chance that a wire's insulation melted and shorted the unit.
If you need better resolution and the names and prices of the components on these diagrams, click on the following links: for the first diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00001?blt=06&prst=0&shdMod=JMC8130DDB for the second diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00004?blt=06&prst=0&shdMod=JMC8130DDB
I hope this info is helpful to you. If you need further assistance, just place a comment.
Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
F82 code
If it's a Panasonic commercial model (NE1757,NE2157), check the two fuses first. If one is blown, first take a look at the upper door switch to be sure it's activating. If that and the bracket look ok, you most likely have one of the following parts that need to be replaced...
Fan motor, HV Transformer, or Magnetron tube (or a combination of). Also look at the two white wires going to the middle relay on the lower relay board. If they're burned, you'll need this board and possibly one of the above parts as well.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
