Question about Sharp R-930AK Convection/Microwave Oven
Why did my sharp microwave lose all power
My sharp microwave just quite, while there is active power supply the microwave is getting no power at all, could it be a fuse if so can I replace it myself?
  • 49 Answers
Remove cover and check small fuse, if fuse is bad it ussually is caused by a failed door switch, hope this helps
Posted on Jan 31, 2010
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
I have a Sharp Model 1460A Microwave. It quit working while warming something up yesterday. Outlet is good. No power to unit at all. No light working, etc. Is there a fuse that I can check to see if it...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 07, 2011 | Sharp R-1460 Microwave Oven
I have a sharp carousel over the range microwave oven R-1505LK no power the outlet is ok did lose power to the house and the microwave didnt come back on where is the fuse located
The fuse is usually located inside the cover near where the power cord enters...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | Sharp R-1505 Microwave Oven
Sharp Microwave stopped working. lights up, counts down. Fine'
High voltage power supply for the magnetron is likely problem. Multi-thousand-volt section--be careful.
Jul 11, 2009 | Microwave Ovens
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
No power
there should be a 20amp fuse that probably blew
Jan 01, 2009 | Sharp R-320B Microwave Oven
Was using microwave to pop quite a few bags of pop corn to feed birds. Microwave is hot to the top to the touch. lights on the front of the microwave are not lit up, no power. WALL RECEPTCALE is active.
Plug fuse may have blown. Replace that first or test.
Internal temperature trip may have cut out (if present)
Microwave generator (magnatron) may have failed.
Internal power supply may have failed due to moisture.
Very likely this machine is dead.
Save energy - and cash, by feeding birds stale bread and raw seed and corn.
Hopefully the next microwave oven will last longer.
The cost of repair may be more than the cost of replacement. Ask your nearest repair shop how much to replace the microwave unit, and check the power supply.
Sorry I can't offer a quick fix for you.
Jun 13, 2008 | GE Microwave Ovens
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
869 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
