Question about Trango Hx HX251 Radio Control Helicopter
My HX252 R/C chopper do not fly. I tried all the procedure but without success. I noticed also that the transmiter has two light: green and red. But do not change during chopper operation. Also i noticed that chopper turn clockise same as main rotor. I tried to disconect the tail rotor and noticed no rotation of chopper, indicating that maybe main rotor do not develop full power. Also i noticed that main rotor is loose ( i stopped main rotor using may hand and gear still rotates
I bought a Polaroid power pack, a pink one. I have tried to charge my cell phone Without success.
Red means it needs charging..... the light will turn green or go off when fully charged.
Aug 22, 2017 | Polaroid Cameras
Lost manual can't figure out how to make it work
I did a thorough google search on line without success. Looks the manual never was uploaded. While there is a remote possibility that some othet Fixya member might give you a more hopeful result, my best advice it to contact Brentwood Appliances. They may have the manual and might send you a physical copy for a fee or a digital version. not for sure but you might try
Welcome to Brentwood Appliances
See phone numbers and contact at
Sep 13, 2015 | Brentwood Appliances MC-105 Mini Food...
Tx red light is use to show what
when you are not talking the light should be an aqua / green color.When you transmit it should turn red. if you see two red lights your antenna is out of match.As for your radio not get out you have to get a friend to listen on another radio and he will tell you if its working or not.
Jul 21, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
Blinking clean light ...
I found a broken chopper causing my blinking clean light problem. A piece of plastic found its way to the chopper, jammed it and broke the end of the shaft off. I found the parts, blade, nut, washer, in the chopper sump area. The chopper screen was clogged, restricting water flow and setting the fault. Another symptom I had was about a month of poor dish cleaning of dishes on the top rack. I replaced the chopper for about $25.00 and everything is fine. Be aware of the replacement procedures, it can be a bear.
I read a comment on not replacing a broken chopper, that a dishwasher had worked for four years without one. I don't know if that's a good idea since chunks of food flow freely into the pump.
Dec 20, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My chopper does fly but only rotates and does not go forward or backward or sideways even. Is it possible to make it fly forward or sideways?
it may be a problem in your remote control of your chopper. if you have the Warranty card and speak about the problem. it may replace your chopper or repair it. All The Best!
Dec 03, 2010 | The Toy Workshop Helicopter
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
Trango Hx HX251 Radio Control Helicopter Logo
400 people viewed this question
Top Trango Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Trango Toy Expert? Answer questions, earn points and help others
