HOW DO YOU FIX THE BELT...I SMELLED RUBBER AND THEN IT JUST STOPPED WORKING..
    Sergeant:
  • 215 Answers
Remove back panel and you will see quite easy to fix. you may need old belt as this will give you numbers for new belt size
Posted on Feb 10, 2010
Inglis dryer is squealing like a belt loose. it subsides during cycle but a burnt rubber smell is very prominent when finished
Replace the belt - it is old and worn out. The belt is made of rubber and is slipping, causing the smell and squeak. The belt heats up and becomes more flexible after the dryer runs a while; this is why the squealing stops.
Mar 26, 2013 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
My dtx1300 burned out when my son kept vacuuming with the bag full suddenly it stop working and I could smell a light burn.what part would do that so I could may be fix it?
the belt that drives the beater bar may have broken. If you noticed a burned rubber smell it was the belt and you can find the part number in your book that came with your machine.
Aug 16, 2011 | Oreck DutchTech DTX1300C with Motorized...
Motor bogged down, smelled rubber, brushes stopped turning
This repair would require motor replacement, based upon your explanation.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
I checked the belt and it has not broken, but when I start to vaccum the spinning head stops, and I start to smell a rubber smell...Do you think I need to replace the belt, I did get some string caught in...
Yes you do need to replace the belt they stretch out. Think of a belt like a big rubber band if you were to stretch it out and hold a lighter to it the rubber band would stay stretched out. That is the same thing that happens when you get it caught on string or an area rug the brush stops but the little metal shaft keeps spinning creating heat and stretching the belt. Visit www.stevessewandvac.com for belts, bags or any other vacuum need.
Aug 13, 2008 | Bissell Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
