Question about Maytag JMC9158BA Stainless Steel 1000 Watts Convection / Microwave Oven
Micro come on but the turntable won't start - Maytag JMC9158BA Stainless Steel 1000 Watts Convection / Microwave Oven
  • 49 Answers
Probably a failed turntable motor, check for power at motor
Posted on Jan 31, 2010
Strange one here, The turntable in my Microwave wont turn off, even after timer runs out and micro shuts down when you open the door the turntable just sits there and spins without a care in the world
Power to the turntable motor is supplied by a relay mounted on the main control board ( the part behind the control panel). Sounds like the relay contacts are stuck in the closed (on) position. You can try getting to the main board and tap the small box looking parts on the board with something like a screwdriver handle and see if you can get it to unstick. If that doesn't work---board needs replaced.
Jun 04, 2015 | In Microwave Ovens
Why wont the microwave start after I have repaired the door lock
If the micro switches for the door are not aligning up then the microwave will think the door is not closed and won;t start so I would make sure the door micro switches are lined up
Nov 04, 2014 | Kenmore Microwave Ovens
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
Prestige gs25 microwave won't heat
no the problem is more than your fuze! Micro waves have a high voltage output transformer inside that goes bad. You can fix it yourself but if your not good with electronics I would have someone else do the job!
Feb 07, 2012 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
Maytag JMC9158BA Stainless Steel 1000 Watts Convection / Microwave Oven Logo
35 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
