Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
My canon 6530 won't print. The buttons light up but when I press print nothing happens. I can print using the computer through the usb cable.
  • 1,219 Answers
When your lamps blink, pls send the eror message that appears on display
Posted on Feb 15, 2010
Why Canon IR2016J not detecte in my laptop windows 7?
Canon ir-2016J not supporting for print. so it will not detect USB. USB can be used for only updating mechine system software.
Aug 15, 2014 | Canon Office Equipment & Supplies
Will not scan to my computer
What OS are you using? Did you install the full software (MP Navigator), not just the drivers? If you have the MP Navigator installed, how are you connecting to the computer? If you are using a USB cable, try a new cable, a different USB port and a direct connection if you are using a USB hub. (If you are using a USB print server, go to a direct connection to the computer.) If you are using the all-in-one over your network, try disabling your firewall temporarily. You may need to add a rule to the firewall to allow the scanner communication. (This will depend on the software/hardware firewall involved. Please add a comment with the details for support on adding rules.) The scanner requires bi-directional communication with the computer. This can fail even though the printer works. Make sure that the monitor program is running; this listens for button presses on the all-in-one.
Next open MP Navigator and try to start a scan from your computer. If you can't scan, then you should check for a communication issue, as described above. If the scan works from the software, then you probably don't have the destination buttons assigned in the software. Use the details from your initial scan to set the defaults. Go to Preferences and then the General tab. Adjust the details for the Scanner Button Settings. Click OK to save.
I hope this helps. Please let me know if you continue to have a problem.
(one common issue for a USB connection is installing the OS default drivers by connecting the USB cable before installing the Canon software. If that is your issue, please uninstall the printer. Then with the USB cable disconnected, install the Canon software. Connect the USB cable when prompted to do so. The OS software usually only has a printer driver and thus will not allow the scanner to work.)
Feb 06, 2014 | Canon MX882 All-In-One InkJet Printer
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
I have an Omnitech 2gb mp3 player. I have used it previously, as previously as a couple hours ago. I uploaded new music and removed it from the computer, but now it won't work. When I turn it on, it is...
Did you checked that a the HOLD function is not enabled ?
It is a button on the player, allowing you to "block" the player in case of unintentional buttons pressings.
Sep 25, 2011 | Computers & Internet
Hi, I have a Canon Power Shot G10, Serial Number 7021002939. I'm making the first ever attempt to download photos from the camera to my MacBook Pro. I wish to use iPhoto to download to the...
Do what the pros do....use a card reader instead of the camera. When you plug it into the USB port, an icon will appear called "NO NAME". Double-click on it and the pics will open in "preview". From there, you can import them to a folder you create on your desktop or into iPhoto. d05ed6a.jpg
Oct 16, 2010 | Canon PowerShot G10 Digital Camera
My scanner isn't working
I suspect you didn't install the full software for the all-in-one on your laptop. Thus you got a generic driver from the OS. If you have the generic driver, uninstall that one, unplug the USB cable and install the software from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=12764#DownloadDetailAct and pick your OS. When the program prompts you to connect the USB cable to the computer, do so.
Another issue may be that you haven't programmed the MP Navigator with destinations for the buttons on the scanner or you don't have the monitor running to identify when the scanner buttons are pressed.
If you can start a scan from the computer, it is probably one of the later two issues.
I hope this helps.
(the generic driver from the OS usually only runs the print functions on an all-in-one.)
Jun 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Can't download images from Canon SD1100 to computer
Hi and welcome to FixYa.
Sounds like your reading right from the manual. <grin>
Try this.
Connect the camera to the computer via the usb cable. Set the mode switch to playback and press the power button, then:
on your pc go to Start>All Programs (or Programs)>Canon Utilities and find Canon Window. Double click on it and it should fire the program. Let me know if you have any problems. If not, feel free to rate my solution.
Rob
Mar 04, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon i550 cannot print
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865)
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Apr 10, 2008 | Canon BubbleJet i550 InkJet Printer
Check Printer Press Resume button
When your printing? thats the problem? Remove the USB cable then turn off the printer, then turn on it again and plug in the USB cable on the USB port. See what will happen?
Feb 28, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
146 people viewed this question
old marine
old marine
