Question about NEC MultiSync LCD4010 40 in. Television
No display I just got a used NEC Multisync LCD4010. Im trying to hook it up to my computer using the digital harness but nothing comes up. The screen shows a kind of grey/blue tint and does nothing. When I unhook the harness from the screen, a red led comes on next to the green power led, and when i plug it back in the red one goes off, and the tint returns but no picture. Ideas?
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Posted on Jun 14, 2008
My NEC MultiSync Lcd4010 turns on, briefly showing input info in the top right corner. Then the red light flashes 3 times and the process starts again. No picture comes on,just the info.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 28, 2014 | NEC MultiSync LCD4010 40 in. Television
Nec 4010
replace leak or bulged capacitors at the power supply board.
Sep 20, 2012 | NEC MultiSync LCD4010 40 in. Television
Where is the lamp located in the lcd4010
the lamp on this unit is the all screen , if you need to replace the lamp , you need to replace the all panel
Feb 03, 2012 | NEC MultiSync LCD4010 40 in. Television
Cracked screen
Tv now dosen't worth as a whole tv anymore.Tv now only can be use as a salvage tv for it electronic boards as for parts for other tvs sets that it now.The tvs LCD screen panels u only can buy it from the tvs corporations themselves only no where else.The tvs LCD screen panels are very important to the tvs sets and 90% of it functions and cost.By replacing the tv LCD screen panel will cost the same as a new tv set.
Aug 29, 2011 | NEC MultiSync LCD4010 40 in. Television
The NEC 4010 i have comes on backlight lights up no information shows on the screen then it shuts off.any idea whats going on here.
Yes,Ur Main Tuner board is defective,it shorted not letting the incomming signal go through the Tuner board,that why u getting a blank baclklight on the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 04, 2010 | NEC MultiSync LCD4010 40 in. Television
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Free monitor does not work with e-machine
go to driverguide.com get update driver.let me know if it help you
Jul 24, 2009 | NEC MultiSync LCD1715 17" Flat Panel LCD...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC LCD4010 no image
Hi Alvee,
Did you find out what the problem was? I am going to purchase the Main Unit so I hope that is the problem.
Jun 14, 2008 | NEC MultiSync LCD4010 40 in. Television
NEC MultiSync LCD4010 40 in. Television Logo
464 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
