Question about Sony RDR-GX315 DVD Recorder
I changed the command mode with my remote and now the remote does not work
There is a slider mechanism in the remote that reveals more keys under the "zoom," "pause," and "stop" buttons on the bottom row of the visible keys. Slide this open, and in the bottom right corner there might be a sticker that says "peel off before using." Under that sticker is a sliding switch. Slide the switch to the command mode to match that of the player. Hope this helps! It worked for me after reading many incorrect ways to switch it back that did not work.
Posted on Aug 26, 2010
When i press the remote all i get is DVD 3
Your player has been set on remote mode 3, you need to change remote control itself on remote-3 so unit can get remote signals.
Set the command mode for the remote so it matches the command mode for the recorder.
Hold down ENTER.
While holding down ENTER, enter the command mode code number using the 3 number button.
Hold down both the number buttons and ENTER at the same time for more than three seconds.
Remote control has been set on mode-3, now player will accept remote commands.
Hope this will help you.
Thanks.
Nov 24, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Switched to command mode DVD1(I know...) book: you will be unable to operate this recorder. That's all they wrote. Can't undo. Nothing works-screen freeze. HELP???
To solve the problem you need to change the command code on the remote control to 1. Point the remote to the unit, and press 1 on the remote.
I had the same problem also.
May 15, 2009 | Sony RDR-GX355
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
Aug 06, 2008 | Televison & Video
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-GX315 DVD Recorder Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
