Question about Samsung DLP HL-P5663W 56" TV
Color is dark and front led light is purple - Samsung DLP HL-P5663W 56" TV
  • michelle noble Jan 31, 2010
    After I posted this I realized that its actually a HLT5687SAX 56- same solution? How difficult is that to repair on you own?
    I actually clicked the incorrect model number- It's a HLT5687SAX 56 - Is the solution the same? Is this difficult to repair?
  • 10,515 Answers
When you have a video problem with a DLP and it's on ALL inputs you have a bad DMD module which is connected on the engine assembly. if not on all inputs then check your signal/box. Check with manufacturer and the list below to price a DMD and also engine, If the price isn't far off you should get the engine because it will come with a DMD module on it. But you can try a old trick use a can of cold spray on the DMD board and see if any caps are leaking, the picture should have a response to the change in temperature if this board is bad, and also on the digital board.
http://www.partstore.com/
http://www.mcmelectronics.com/
http://www.encompassparts.com/
And this one rebuilds board's very helpful company
www.PTSCORP.COM
And also manuals sites
http://www.free-service-manuals.com/
http://www.s100-manuals.com/
http://www.eserviceinfo.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 01, 2010
  • taran_2005
    taran_2005 Feb 01, 2010
    Oops i have not read the Comments!!
    This is a Tech Job. I am afraid, that's the straight answer for the Solution you Asked. I usually advise people with TV repair experience to Fix such a Problem.
    Hope i helped you.
    Thanks
  • Samsung Master
  • 5,138 Answers
DMD module needs to be replaced Call Encompass Parts 1-800-638-3328 or UED 1-800-648-6657
Posted on Jan 31, 2010
  • ladywinn
    ladywinn Feb 01, 2010
    DMD, Module replace it. HLT5687 Basicly Same TV _Module just plugs in make sure you mark all plugins Label them , Call companys Listed or Look for Part on E-Bay under Electronics Thats where I got Parts for my Samsung DLP. If the Problem was your Optical Block/light engine you would have either Spots on screen or picture on screen would have a big Green or purple picture on both sides
    You may want to CK on your power supply board for defective capacitors 1000uf 10v/16v if you do not see any that are vented on top or puffed up on top board is OK ,this is a common Problem with samsung also.
Screen is too dark and unreadable fix it
The screen on what make and model device?
Jul 10, 2013 | Computers & Internet
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Need the radio wiring diagram for a 95 camaro
yellow is power . red is ignition or acc. black is ground. front speakers : left positive tan, left - grey , right - light green , right + dark green , rear speaker : left - yellow , left + brown , right - light blue , right + dark blue . this is for the fatory wire color code if u need the actual wire color code for cd player it is . white is front left , grey is front right , green is rear left , purple is rear right. solid colors are positive and wires with the colors listed with black stripes is for the negative
Mar 08, 2010 | 1995 Chevrolet Camaro
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
A B C D E F G H I J
K L M N
F Not Used
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
Putting in a alpine deck into my cirrus
Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Ground/Back Strap Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Light Green/Green Left Front (-) Light Green/Purple Right Front (+) Light Blue/Green Right Front (-) Light Blue/Purple Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Blue/Light Blue Right Rear (+) Dark Blue/White Right Rear (-)
Dark Blue/Orange
Mar 28, 2009 | Alpine CDA-9847 CD Player
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
Samsung DLP HL-P5663W 56" TV Logo
Jerry Greenberg
Jerry Greenberg
