Question about Whirlpool Dishwashers
Whirlpool model KUDSO1FL not starting cleaning
Whirlpool model KUDSO1FL not starting when cycle selection is made and start button is pushed. The cleaning indicator light blinks but nothing else happens. What is the problem?
I fixed the problem by hitting Hi-Scrub then Economy Dry in sequence four times in a row. All of the lights came on, I am assuming to reset it the program, then went off and the start button was highlighted. I then pressed cancel and then selected the program that I wanted to wash with and pressed start. It worked like a charm.
Posted on Feb 02, 2010
  • danschnee Jan 27, 2014
    this worked for me too! THANK YOU!
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Washer will not start
Does the dishwasher plug in under the sink or is it hard-wired? If it plugs in under the sink unplug it and let it stay that way for 5-10 mins and see if that changes anything. If it is hard-wired see if you can figure out which breaker it is on and turn it off for same amount of time. Let me know.
Thx
Jul 31, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
265 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
