Question about Microsoft Windows XP Professional
Backing up computor files
DVD does not download backup info.
  • 22 Answers
Install freeware DVD shrink.It will copy the backup files to the DVD very easily.
Posted on Feb 01, 2010
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
I have ran out of memory on D section of my hard drive but have not put any thing on it I thing this could be some thing to do with backing up ? because Ive noticed that when computor has backed up memory...
You are absolutely correct. The D partition in your hard drive is getting full. Delete the old backup files to make more room in the D partition.
Nov 23, 2010 | Computers & Internet
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
They are probably in a format that the pda can not handle.
Sep 14, 2009 | Palm Tungsten E2 Handheld
Having a problem with backing up files
ok..so what kind of computer do you have, and what are you looking to back it up to?
Oct 20, 2008 | Packard Bell Computers & Internet
BackupBuddy VFS Pro supports the LifeDrive?
The readme info needs to be updated. The current readme is actually from the previous version and out of date. It should now look something like this.. (note newest info at top, previous version info underneath) BBVFS 3.1.4 New features include: + added option to backup after HotSync + LifeDrive compatibility fixes Bug fixes include: - some password letters were being ignored - fixed problem of backing up files encrypted with the built-in Security app - blank screen/crash on startup - crashes during orphans processing - no scrollbar appeared when there were more than 10 checkpoints in the list - didn't fail gracefully when trying to restore corrupted backup files BBVFS 3.1, 6.05 * Users may now select which card to backup to on devices with more than one card slot * Backup and Restore of T5 internal drive (!) is now supported * Backup of databases with records > 64K is supported, which will allow backup/restore of Photo/Videos on T3/T5/T650 and "VoiceDial" application * Advanced screen now adds new files to the backup set automatically * Wireless updating (via "About" screen) * Implemented a Palm Source Installer package * Many important bug fixes, including: Several issues relating to compression and encryption "Last Backup" being incorrectly set to "NEVER" No longer will soft-reset if no card is mounted on the T5 TUNGSTEN T5 SUPPORT This build includes further refinements to backup and restore on the T5 but we have confirmed with PalmOne that there are some issues with the T5 NVFS implementation that require a patch from to completely resolve. We recommend that all users download and install the T5 patch that is available here: http://www.palmone.com/us/support/d...ent5update.html Alternatively T5 users may want to try a program called "DBCache Tool" which you may download here: http://www.jade.dti.ne.jp/~imazeki/palm/DBcT/ LIFEDRIVE SUPPORT We are aware that this release contains some remaining issues with the new PalmOne LifeDrive and we are working to resolve them. Please contact support@bluenomad.com if you'd like to help with testing. BBVFS 3.07, 1.05 BackupBuddyVFS 3.07 is being released with preliminary support for the T5/Treo 650, although there are still some outstanding issues that we are continuing to investigate; specifically: * Power Users with a (near) full device especially may experience "out of memory" errors and/or random resets; restarting the backup or restore operation will usually allow it to reach completion. This is due to issues with the new "NVFS" file system on these new devices that developers cannot currently work around. We hope that palmOne will issue a patch to fix this, and we will continue to try and find a work-around. * Photos and Videos will not be backed up on the Treo 650/Tungsten T5.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Prob with hot sync
You have to do a clean sweep of office.
Sep 12, 2005 | Palm Treo 650 Handheld
650 stopped syncing after I set up the email function
Reinstall software. If this is helpful, please post as such. TY
Microsoft Windows XP Professional Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
