Question about Krups 65475 WaffleChef Waffle Maker
How do you know when a waffle is finished cooking
  • 1,476 Answers
It should be light brown on the outside and have a hard cover. It only takes several minutes at the correct heat setting.
hardrocko
Posted on Jan 31, 2010
4 Suggested Answers
SOURCE: Turns on but doesn't Cook
Sounds like the Thermo safety limit has gone out. This goes out when the theromstat goes bad. There is no service done on this product. Call the company about getting a replacement while it is still under warranty.
Posted on Feb 24, 2008
  • 33 Answers
SOURCE: How do you know when it is done cooking?
Usually there is steam rising from the waffle maker when cooking, if there is no light on it to tell you when it is done watch the seam and as it is getting done there will be less steam than when it first started, if there is a light watch when it goes off or when the steam stops and then count minutes to when you open it to see how browned toasted you prefer
Posted on May 21, 2009
  • 1214 Answers
SOURCE: only one side of waffle maker will cook
Sounds like either cord that passes power from one side to the other at the hinge had broken, or the heating element in the side not getting hot has failed.
There is no easy way to repair either of these problems without strong knowledge of making repairs to high temperature wiring.
Posted on Dec 11, 2009
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
Jan 11, 2013 | Kitchen Appliances - Others
Why does the waffle stick to the maker and how do you clean it???
Waffle pans are seasoned through usage. If you clean the pans too well, they won't work right. It's a bit like cooking with a cast iron skillet. If you wash it with soap and water, you strip the oils off of it, and it will rust.
Use some Pam or similar product when you get ready to make your waffles. Spray the lower pan, add your batter, and then spray the upper pan. Close the waffle maker up quickly after spraying the upper pan.
To clean off old material, it's easiest to scrape it off with a nylon scraper, taking care not to score the metal. A bit of the cooking spray will help on the most stubborn baked on material.
I personally prefer to use the batter that requires the addition of cooking oil, and I still spray the pans as well. This leaves me with a seasoned waffle making machine.
When you've finished with the waffle machine, wipe down the outer surfaces with warm soapy water, followed by clean water. Clean the pans the least you can. Usually, if the waffles are leaving little to no residue, we just wipe the pans clean with a paper towel, and then put it away.
By the way, the first waffle in any given batch seems to never be as good as the ones that follow. We call this one the "sacrificial waffle" and move on. Our dogs appreciate it!
Best regards. Hope that you found this somewhat helpful. --W/D--
Jan 30, 2011 | Waring WMK300 Professional Belgian Waffle...
I don't know when my waffle is done
it will have a warning signal on it,,,,,its called smoke?
even flames if its realy desprate!!!
the thing is its cooking,,, and thats not an exact sciences, so realy you just lift the lid to have a look, just like you test a cake, stab it with a knife? and flick it with your finger,, if it rings its cooked
Feb 16, 2010 | Krups 65475 WaffleChef Waffle Maker
Need to know how to clean the waffle cooking plates. Do they come out?
They do not come out you - before cooking you need to spray with non stick cooking spray - after cooking you clean with soap and spong on counter DO not submerse into the water - keep the plug away from water - wipe clean with damp cloth
Feb 07, 2010 | Toastmaster TWB2 Cool Touch Belgian Waffle...
May 17, 2009 | Krups 65475 WaffleChef Waffle Maker
I need to know the temperature for making waffles
I finally found the manual for this grill. It says that waffles should be cooked from 3-5 minutes on high uingd 2/3 cup of batter. There is an entry on this website where you can download and print the manual with suggested cooking times.
Jan 06, 2009 | George Foreman G5 Indoor Grill
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
Krups 65475 WaffleChef Waffle Maker Logo
146 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
