Question about Troy-Bilt Pony Garden Tiller
Just bought a pony with a five horse the carb seems to be giving way to much fuel fowling the plug and spraying out the muffler
  • 714 Answers
Sounds like the float level in the Carb is stuck open or set to high.
RECOMENDATION:
Shut off fuel and remove float bowl and inspect for proper operation.
INFO:
You most likely have trash keeping the float valve open or out adjustment..
Hope this tip helps.
R/
David
Posted on Jan 31, 2010
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
My 5 horsepower pony tiller just shuts off with no warning after about 20-30 minutes of tilling and will not restart again until it cools down to the touch I have changed the spark plug, drained and...
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Mar 23, 2011 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Won't start not getting fuel
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 28, 2009 | Homelite Garden
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 25, 2009 | Craftsman Garden
I bought a second hand RYOBI PLT3043a line trimmer and am failing to start it.
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 25, 2009 | Ryobi Garden
When i open the throttle a little, the speed increases but at full throttle, the power drops and I lose speed. Admittedly, I bought the C/Saw from a market 'as seen' and I found a few problems like broken...
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 24, 2009 | Heavy Machinery
I have a 22 inch 25CC gas hedge trimmer that will start fine but only run for 30-40 sec. in the "full choke" position before stopping. It will also stop if I try to give it gas. What should I do?
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 21, 2009 | Homelite Garden
Give it gas slows down
1) spark plug
Chain Saws:
Remove Carburetor
Nov 20, 2009 | Homelite Consumer Products Backpack...
CRAFTMAN LEAF BLOWER WONT START
1) spark plug
Chain Saws:
Remove Carburetor
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
It would not crank up so i replaced the filter in the gas tank and seemed to have put it back together right
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 14, 2009 | Garden
Troy-Bilt Pony Garden Tiller Logo
311 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
