Question about Kenmore Dishwashers
Model 363.15129100 will not pump out water. Serial # LF 300750R
I keep getting error code "LF" , it only makes it through prewash.....please help
Owner's manual, troubleshooting. no manual, try manualslib.com
or one of the many online appliance parts sites may help diagnose based on make model possibly year and or serial.
Apr 05, 2015 | Washing Machines
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Code ce and lf
If there is any breakdown in communication between the machine controller and the motor
controller, “CE” flashes and the unit beeps once.
Some common causes of “CE” errors include:
• Conformal coating on serial communications pins between the machine controller
and motor controller. After disconnecting power to the unit, try scraping this coating
off the pins.
• Check the resistance values between the serial communications pins with the
connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked
up properly or a “CE” error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display
If the water fill time exceeds ten (10) minutes, the water valves are turned off and “LF” is
flashed.
Press STOP/CANCEL to clear the display.
Aug 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Oasis elite top load washer
LF code LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
You will need to check you fill hoses this is 95% of the problem in the rear of the unit ther are two hoses Hot and Cold feeds shut off the water and Unplug the unit Then remove the hoses from the machine. in the Valve where the hoses go to there are little mesh screens they are most likely clogged take a eyeglass screwdriver or paper clip and hook the screens pull them out carefully and clean them reinstall and connect hose and test
Dec 19, 2007 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
96 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
