Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Slow pc performance takes time to open any program
  • 36 Answers
You should download this and install it then when you are done installing cleanup open it. make sure you tell it that you don't want to run a demo then when you finish let it log off. i hope this helps. and if it does please rate my solution thanks and good luck!!
Posted on Jan 31, 2010
  • jakeswoody
    jakeswoody Jan 31, 2010
    click on this to open download window
  • jakeswoody
    also try downloading malwarebytes at malwarebytes.org this is , in my opinion the best free anti virus scanner and there is no need to uninstall other antivirus programs when you install malwarebytes.
Computer slow to start,open files, load web pages, slow shutting off.
try to delete large file or free space your disk , you can see your CPU proccess in task manager if your cpu work 100 % ,that makes your laptop become slow , try to disable program on start up windows->run->msconfig disable program and then try to maintain your laptop performance with utilities like advance system care or tune up utilities , defrag your harddisk , if your laptop still slow , try to reinstall your OS if this happen , then your hardware have trouble
Feb 17, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Having slow performance? Make your PC/laptop run faster (only for WIndows XP)
There are some steps which you can try to boost your Windows XP PC/Laptop's speed & performance:
1) Removing Startup items
Click Start, point to Programs, click Startup, and then right-click each item in Startup and select Delete. Your Startup folder should be empty
2) Remove unnecessary programs from Add & remove programs list
Click Start, point to Settings, and click Control Panel. Double-click Add or Remove Programs icon.
Scroll through the list of installed programs, and remove the one you don’t need. Be sure about the programs those you don't need.
3) Setting PC/Laptop for best performance
Right-click My Computer and select Properties.
Switch to Advanced tab and click the Settings button under Performance subsection. Performance Options window will open.
Select Adjust For Best Performance option and click OK button.
This may degrade the looks but will increase the performance of PC/Laptop.
4) Right-click My Computer and select Manage. Computer Management window will open. Maximize Computer Management window.
Click plus sign next to Services and Applications, click Services, and switch to Standard tab on the right.
Disable the following services one by one:
Alerter
Background Intelligent Transfer Service
ClipBook
Error Reporting Service
Fast User Switching Compatibility
Help and Support (switch to Manual)
Indexing Service
Messenger
NetMeeting Remote Desktop Sharing
Performance Logs and Alerts
QoS RSVP
Remote Desktop Help Session Manager
Remote Registry
Telnet
Upload Manager
WebClient
Wireless Zero Configuration (don’t disable if using wireless network/Internet connection)
To disable the service, search the service name in the list of services & double-click on it. Change Startup Type for the service, selecting Disabled from Startup type dropdown box and clicking OK button.
Restart the computer.
5) Run CCleaner regularly.
Download CCleaner application from here. Install it.
Run it time to time to run your PC smoothly.
6) Defragment hard drive (may take up to 30 minutes or more than that)
Click Start, select Programs, Accessories, System Tools, and click Disk Defragmenter.
When Disk Defragmenter window opens, select a drive in the top portion of the window, and click Defragment button.
on Jun 15, 2010 | Computers & Internet
Why is computer slow fungsation any time hang
Do you mean slow function ? .a computer hangs when you do not have enough memory (RAM) installed and to many program.
Jun 05, 2013 | Computers & Internet
Recently the speed of my computer has got very slow
Have you added any programs recently?
When is the last time you defragged your hard drive?
When you run task manager, are there many open programs?
Sep 10, 2012 | Compaq Computers & Internet
Slow performance
First of all, SAVE ALL OF YOUR IMPORTANT DATA! Not programs, just Data. You can reload the programs.
Open Internet Explorer, Tools, Windows Update. Select Custom.
Install all the updates. Repeat until you no longer have updates to install.
Click Start, All Programs, Accessories, System Tools, Disk Cleanup.
While that is running open your TEMP folder and delete everything in it. Then open the Windows folder and delete all files starting with $NTUninstall. In the Windows\TEMP folder and delete everything.
After that I like to search for all *.bak; *.tmp and ~*.* files and delete them.(They're all temp files)
After all that Open My Computer and Right Click on the C: drive. On the Tools Tab select Check Now. Check Automatically Fix Errors and Scan For and Attemp Recovery of Bad Sectors. Click START and reboot your PC. This will take a long time. When that is finished, go back to Tools and Select Defragment Now. This also will take a long time.
This whole process takes a long time if this is the first time you've done it so, be patient.
Jun 06, 2012 | Toshiba Satellite U305-S2808 PC Notebook
My commputer is very slow could you help me speed it up?When opening a program it takes 10-15 mins gpr a program to open.
You probably have a number of viruses on your computer. My suggestion is to download these two programs and uninstall your current anti-virus software (if any).
AVG Free:
http://free.avg.com/us-en/homepage
AVG is a great anti-virus program that will always be running and protecting you.
Maleware Bytes:
http://www.malwarebytes.org/
You will want to run this free program as soon as you download it. It will remove any viruses on your computer. This is a great tool to use about once a month to make sure your computer is clean. Do a full scan and wait for it to complete. If you have completed the steps above and still have the problem, you will need more RAM. RAM is temporary memory that your computer uses when it is on. If you have very low RAM, then you will have a very slow computer.
May 16, 2011 | Computers & Internet
Slow computer, seems to hang alot. how do I speed it up. done all the usual things.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
Jul 10, 2010 | Compaq Presario Notebook
Running very slow. Takes a long time to boot up and slow to respond to programs on this computer. I've deleted many programs I rarely use as a result, but it still is too slow for my satisfaction. I bought...
there is many issues that can cause pcs and laptops to run slow removing programs probably wont help that much you need a cleaner program like ccleaner or auslogics boostspeed which is a good one! www.ccleaner.com or www.auslogics.com/en/software/boost-speed
Jun 29, 2009 | Dell Inspiron 710m Notebook
System is becoming slow
Open your control panel. Select the performance and maintenance option. 1st run a disk cleanup, after that has finished run the system defragmenter. Once these have completed reboot. Hopefully your problem has been corrected. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Microsoft Windows Xp Home Edition English...
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
