Question about Sceptre DCL9a
Volume quit very fustrating.
I have a DCL9A monitor. I'm also having problems with my volume. One minute it worked the next it quit. I tried turning the volume up that didn't work. I'm not computer wizard, but if I had to guess the problem is inside the monitor. I sure could use some help figuring it out.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Hello, My Graco monitor shows a red light instead of the normal green light and it says "discard jetez". It also beeps. What could be wrong?
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Mar 12, 2011 | Graco Imonitor Vibe 2791vib Digital Baby...
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
I cant hear the volume on my computer
I presume that it worked at one time and now it doesn't. I don't know what operating system you have, but generally you shoud see a little speaker icon on the lower right hand corner of your monitor, next to the time. Doble click on that and it should bring up the volume control. Besure that the "mute" is not on and that the volume is turned up to at least the middle area. If this doesn't fix your problem then there are some deeper fixes that can be done
Oct 31, 2009 | ViewSonic G771 17" CRT Monitor
Hi, not sure if you can help me or not, but all of my sudden the monitor is not working (only see red light, no green light). I have charged the battery but it does not resolve the problem/ Any idea what...
Oct 25, 2009 | Graco Digital Deluxe Imonitor With...
Osd lockout and automaticv volume decreases on hpw1097 compaq com
Change the front control panel switch set.
this is the major problem
available in market
Thnks
TENNISON.J
tennison_2006@rediffmil.com
+919901642228
Aug 29, 2009 | HP Compaq WF1907 Monitor
My garmin nuvi 205 quit talking. volume is at 100% and not on mute. beep sounds work but when in route i have no next turn or direction sounds. screen map does work.
I have a 750. I went to settings, language and restored the defaults. The Voice was blank when I went to that screen. I am not sure if the 205 has the language setup or not, but this should solve other Garmin problems. And as a bonus, if you want to solve the problems with the US, Fire Congress check out http://FireCongress.org
Nov 07, 2008 | GPS
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes...
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Mar 13, 2008 | NEC AccuSync LCD223WXM Monitor
Turn on the monitor the screen says "out of range" in a small window and turns off
Lower down resoluction and color quality to minimum on your pc, using 'display properties' in Windows. Connect the monitor back to pc with minimal settings. If it works is done.
If it still does not work there is a major problem with the monitor. In this case It should be opened and tested inside following schematics. In this case you may need to take the monitor to a service in your area.
regards
Mar 02, 2008 | Sceptre DCL9a
Sceptre DCL9a Logo
139 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
