Question about Danze Plumbing
Danze D404214. Just stoped flowing from spout,
Danze D404214. Just stoped flowing from spout, the sprayer still sprays and when you use sprayer a trickle of water comes out spout
SOURCE: danze sonora roman tub personal shower stopped
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Posted on Jul 14, 2009
  • 23 Answers
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Posted on Jul 20, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
  • 175 Answers
SOURCE: Sulfur smell from the Delta faucet
Your incoming water from the well is contamiated. A delta faucet will combine oxygen with the water and make the sulfer smell come out. It could also be iron bacteria causing the smell. Look in the back of your toilet tank and see if your have reddish or black stringy algae looking stuff growing in there. If you do, you have iron bacteria and it will smell.
Posted on Nov 20, 2009
SOURCE: My Danze NSF 61 9 makes a loud howling noise.
You don't say how old your unit is. I have had the same problem with calcium buildup in my tankless heater. Pump vinegar into the unit and let is set for about and hour, then flush the unit.
Posted on Feb 26, 2010
Leaking pull out spout
Usually, it is caused by a worn out o-ring.
Jan 31, 2014 | Danze D403412 Melrose Single Handle...
Brand new Danze kitchen faucet set just installed by master plumber and has continued flow after shut off and company help says that is normal. We disagree--son has a Moen with same curved spout and it...
Sir, I agree with you. I suggest that you request the company Danze to resolve your complaint. Maybe the company Danze personnel can do something by adjusting the clearance inside to immediately stops the flow of water. Thanks for asking FixYa.
Jun 14, 2011 | Danze Plumbing
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
When the water is turned on, the faucet "sputters" and "hammers" as if the water had been turned off then back on when it hasn't been. Plumber says we need new part (inside cartridge 070807-Aqua Source)....
The USUAL cause of this is the diverter valve that channels the water to the sprayer. There are several types of these so search for yours in google to find a blow-up drawing of it. They are usually in the tower the spout swings on and sometimes are a pintle valve like a little rod with dumbells on the ends. Crud can make them not seat then they will cause the hammering.
Mar 09, 2010 | Danze D403412 Melrose Single Handle...
Kitchen faucet leaking pull down sprayer spout type
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Apparent flow blockage
I would turn off the water then check to make sure you have good flow up to the faucet itself. If you do then there might be a proplem with the cartridge or diverter. does it have a sprayer? If it has a sprayer head for the spout of the faucet then there will be what the call a check valve inside the spray head itself that canbe removed with a skinny screwdriver or something thin and long
Apr 29, 2009 | American Standard Kitchen Faucet 6310 020...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
115 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
