Question about Garden
The gas lines on my craftsman chainsaw rotted so i am replacing them but i dont know which goes where
    President:
  • 2,220 Answers
A typical fuel system and a couple of suggestions can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
You can likely find an IPL for your saw here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128416&sid=PSx20071217x00001a&OVMTC=Broad&site=&creative=3268989744&OVKEY=craftsman%20parts
Almost all Craftsman chainsaws are made by Poulan. If you provide the engine and bar size I can almost certainly provide a link to the applicable Poulan IPB.
Fuel line can be obtained at any local chainsaw outlet. 12” of any different sizes is probably ample but inquire within. I recommend you take a small sample of each different size.
You can reply below with the numbers or any questions you may have. I hope you found this most helpful.
Lou
Posted on Jan 31, 2010
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 | Garden
Need a digham for poulan chain saw fuel lines the old ones dry rotted and i dont know how to install the new ones
James I have the same problem. Can you help with a picture or instructions on how to fix please
www.oneway@bellsouth.net
Thanks, .
Oct 03, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel lines rotted. Replaced but cannot prime. Primer pushes back into tank causing fuel to leak at cap vent. Would like to obtain parts manual
i recently worked on a chainsaw that i was putting back together and got the primer bulb lines crossed, it was backwards to the way it should have been, i recommend that you reverse the lines, it is an easy mistake to make when it can be counter intuitive like it was in my case
Jun 28, 2011 | Craftsman 25cc Gas Line Trimmer
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
1,164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
