Question about Samsung HLN617W 61" Rear Projection HDTV
Hooking up blue ray to Samsung 1080 DLP
I am trying to hook up a blue ray player and when I plug in the HDMI it says not supported mode on the TV. I am also trying to hook it up thru the Bose surround system. I have an optical cable as well but cant get it to work.
  • 69 Answers
If the tv is not a 1080p model it will not accept a blueray signal and the optical output from the tv only works thru its own tuner not with the inputs or cable boxes
Posted on Feb 07, 2010
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
Samsung LCD TV LN40A550P3F will not support 1080 format when hooked up to HDMI via Directv receiver.
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
Feb 12, 2011 | Samsung LN40A550 LCD TV
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
My tv shows the message mode not supported to a new blue ray player
Make sure the Blu-Ray player is set for 720p or 1080i only as this TV will not recognize 1080p or even the 24fps mode that some Blu-Ray players have.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
I just bought a samsung bd -p1600 and connected to a samsung plasma tv, it just comes up not a supported mode. tried 2 blue ray disks with no luck. switched from hdmi 1 to hdmi 2 input with the same...
Check that the player is set-up in to a mode that is supported by your TV set. You should consult the user manuals of both the TV set and the player to follow through. Another solution which may be easier is to colll the Samsung service support.
Jerry G.
Sep 25, 2009 | Samsung Televison & Video
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
"Not Supported Mode" on Samsung tv with Philips DVp5990
The solution turned out to be connecting with a DVI-to-HDMI cable.
Mar 19, 2009 | Samsung HLN467W 46" Rear Projection HDTV
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Samsung HLN617W 61" Rear Projection HDTV Logo
283 people viewed this question
Henry  Thomas
Henry Thomas
