Question about Sony KDSR50XBR1 50" Projection HDTV
Can I replace the lamp myself? - Sony KDSR50XBR1 50" Projection HDTV
  • 1,476 Answers
Steven, you should be able to if you can use a screwdriver. Get your model number off the rear of the unit. Go to www.partstore.com . Put your model number in the search and find your lamp. Depending on the model TV the door to access the lamp may be on the back, front or side. It will be in your manual. Remove the door, remove the lamp, replace the lamp with the new one, replace the door and your unit should be good to go. Hope this helps. Let me know.
hardrocko
Posted on Jan 31, 2010
Lamp expired can I find a new lamp & can I replace it myself
Hello Ann Welford,
Welcome, and thank you for using FixYa!
To answer your question: I don't recommend replacing the bulb on this unit.
Not only did HP design these scanners in such a way as to elimnate "User changable parts" but it would not be cost effective. You can buy a replacement scanner for this unit for close to $75.00 and it will have newer features and software controls.
Have a great day!
Oct 24, 2011 | HP Scanjet 4370
My Sony KDF-E60A20 tv is not working this morning my lamp indicator was flashing is this a problem i can fix myself or is a service technician needed?
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side. if not found then tell service center only model number of your tv and get your Lamp. Lamp replacement way menstion in Lamp user manual.
Oct 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Can I change the projector lamp myself
Lamp replacement is user level repair and mostly written with details in related user manual of tv.
Please check user manual of your tv for more info or let me know if you have additional question.
Thanks.
Jun 28, 2010 | Sony KDS-60A2000 60" HDTV
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Change Lamp. Is this something I can do myself?
yes. remove the lamp door and the lamp, replace with a good lamp (the exact type), replace the door.
Jan 29, 2010 | InFocus Office Equipment & Supplies
My lamp light is on. can i change it myself ?
Hi your part number is TYLA1001 found it here : http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001 It should be around the back.
Oct 01, 2009 | Televison & Video
Replaced lamp on Hitachi 50V720, still have flashing red light
Just make sure the Box (Lamp Enclosure) is pushed in firmly on both sides, left and right. Left side to hit the power connection and Right side to hit the little relay switch, Must be flush against that back side. It happened to me and I was kicking myself in the ***, a entire weekend went by with a brand new lamp sitting in the enclosure but not completely set in correctly with a flashing red light.
Feb 21, 2009 | Hitachi 50V720 Television
Bought new projection lamp, want to install it myself--how to??
The best instructions for replacing the lamp can be found in the owner's manual. You can get a free copy by copying the following address into your browser:
http://www.docs.sony.com/release/KF50WE610.pdf
Dec 24, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Replacement of Lamp
when lamp goes out frequently.
all lamp filters need changed...call tech
Jun 07, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
