Question about SMC EZ Connect (SMC2655W-KIT) 802.11b
SMC EZ Connect Access Point apparently not connecting to wired router
I've recently obtained an SMC EZ Connect 802.11b wireless access point (model number SMC2655W v1). I've connected it to a LinkSys EtherFast Router (model number BEFSR41 v 1.0). Also connected to the router are my desktop and my cable modem.
The status lights on the router don't light up or respond in any way when I connect the access point. The SMC utility does not detect the access point, and I get no response when I attempt to access it using its default IP address (192.168.0.254). The power light on the access point is on, but other than that, there is no sign of activity.
I've tried using different ethernet cables, and have tried connecting to different ports on the router. I've also tried the "RELOAD" button on the access point. If it matters, my max DHCP users on my router is set to 50.
Does this sound like a faulty access point, or am I doing something wrong here?
Thanks
  • 611 Answers
You doing something wrong there.
give the mac address of smc to the access point that's all you get it
Posted on Jun 20, 2008
2 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: Hi, I have a problem. I wanted to filter the
The address you wrote is not a MAC address, it's an IP address. The MAC address is the physical network card address.
A MAC address has a form xx:xx:xx:xx:xx:xx, or as Microsoft likes it, xx-xx-xx-xx-xx-xx, where xx is a pair of hexadecimal digits (from 0 to F).
You can find out your cards' MAC addresses either by inspecting the card hardware, where often it's written on a label, or using "ipconfig /all" command (from the command prompt) - it will show you the physical addresses of all the installed network adapters.
If you have locked yourself out completely from your router and cannot access it's configuration page, you will have to reset it to factory default settings (see manual on how to do that) and re-configure it from scratch.
Posted on Oct 28, 2009
While connecting thru router,it showing limited access frequently
Do you leave the router switched on all the time? If not then this can be your problem as some routers can take up to 3 days to get full signal strength and keep it. When switching the router off and powering back up it has to search for the signal again. It will happen whether you are wireless or cable.
If you are wireless and router is always on it may be where it is located, walls can interfere with the signals so try moving it to another area to see if that helps.
Jan 01, 2013 | SMC EZ Connect g WEBT-G 802.11b/g Wireless...
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to...
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Mar 07, 2011 | SMC EZ Connect g SMCWEBT-G
How do i secure my wireless laptop
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 19, 2011 | SMC EZ Connect
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Card sees the network, but says no response from access point.
On computer driver, if you lost your cd drive disc or broke the cd you can download them by doing the following steps:
1. Go to your manufactor's website.
2. There should be a search bar on the top of there website.
3. click in the search bar and enter your model number of the
computer or you can enter hardware model.
4. After you hit you come accross to technical support page click on
that.
5. There should be a word pertaining drivers click on that.
6. Finally, click download and download the correct version of driver for
your windows.
Dec 09, 2009 | SMC EZ Connect g SMC2802W 802.11g/b...
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
My wireless lose the pasword key
-You need to access your router user interface using a wired pc to the router, by typing the router IP on the address bar of your browser then it will ask you for a username and password.
-Then on that page you will have options where you can enable again the wireless security just enable again the security from that there.
May 06, 2008 | SMC (SMC2555W-AG UK) 802.11a, 802.11g/b...
How to Configure Nomadix AG2000W from scratch
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 21, 2008 | Nomadix AG-2000W 802.11a, 802.11g/b...
SMC EZ Connect (SMC2655W-KIT) 802.11b Logo
756 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
