Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Washer won't drain
Machine goes through wash no problem until it gets to the drain just stops no sound from motor wont drain. pump is working think maybe the timmer please help
  • 66 Answers
While machine is on move the timer little if that start working it is the timer. and that can be replace very eaisyle
Posted on Feb 18, 2008
Kenmore 70 series model 110.20722990 wont drain and spin
It could be the timer or circuit board, until it is not draining, will not spin
If the timer or circuit board is OK, the you have a faulty drain pump or motor, to check this out remove the back panel.
Mar 12, 2013 | Kenmore 22422 Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
Jan 24, 2018 | GE Spacemaker WSLP1100D Top Load Washer
Won't drain. Motor wont come on.
Possible fault with the program controller unit. Now if there is no power to the drain then it can be due to the controller and if there is power with no drain then it can be due to faulty drain motor or the drain valve beingg choked or clogged;
click this link for tips: Drain valve cleaning
Jun 25, 2012 | LG WM-2277HW Front Load Washer
Washer won't go past the wash cycle
YES !! check out the DRAIN MOTOR PUMP it could be clogged , AJ
Dec 18, 2009 | Fisher Paykel EcoSmart GWL15
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
54 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
