Question about Refrigerators
GE MODEL# GSS25XSRC SS Noisy Evap Fan in Refrigerator & Freezer Repair. ''I have a fan in my freezer that is making a very awful humming sound.
  • 619 Answers
Main board is going bad. Part number WR55X10942, less than $200.00 and easy to do yourself. Located on back side of refrigerator. Hope this helps. It is your board and don't let anyone else tell you any different.
Posted on Jan 31, 2010
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
GE side by side Refrigerator makes LOUD SQUEAK when running
Mar 24, 2009 | GE Refrigerators
GE Refrigerator Problem
you have a leak in the freon line
Aug 16, 2008 | GE Refrigerators
Evap fan not working
you must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Mar 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
