Question about Dishwashers
Hotpoint dishwasher BFV620 lights 2 and 4 flashing and will not complete a cycle. Dishwasher has been working ok but suddenly stopped and lights 2 and 4 flashing. Checked obvious blocked filter and kinked pipe etc,
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 2318 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
You may be able to find some info here: http://www.applianceaid.com/drain_wash.html
Posted on Feb 11, 2008
  • 55 Answers
SOURCE: hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Posted on Feb 15, 2008
aborcass
  • 2651 Answers
SOURCE: Dishwasher not draining
remove the clamp holding drain tube to disposer, unplug disposer, and see where clos is its gotta be right there, UNPLUGGED.UNPLUGGED you can stick a screwdriver thought drain hole in side of disposer to clear debris
Posted on Feb 23, 2008
On a Hotpoint Dishwasher BFV620 what does the preliminary wash cycle light rapidly flashing on switch (on cycles) indicate
Dear Sir:
read carefully the instruction manual, in section troubleshooting for to clear the error. If you do not have download for free. www.fitness.manualsonline.com or www.retrevo.com
see the diagrama attached.
sincerely. God bless you
May 05, 2012 | Dishwashers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Jun 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
