Question about eMachines T5048 PC Desktop
My fan shuts off or runs slow where can i get a replacement and how much will one cost?
    Sergeant:
  • 279 Answers
You are going to need to know exactly what size, and what voltage you need to replace it with. If you remove the fan in question, there should be info labled on it (Make, speed, voltage, part number, etc.) I also found some good DIY info here:
http://reviews.ebay.com/Do-It-Yourself-Computer-Fan-Replacement_W0QQugidZ10000000000104252
Also you can click here to see what kind of variety this guy has to sell to you:
http://stores.ebay.com/The-PC-Fan-Van-and-Gary-Gs-Records
Hope this helps.
Hope this helps.
Posted on Feb 01, 2010
2008 ford expedition air conditioning problems
the ac pressure depends on the gas in use
r314 runs at high pressures
overheating at slow speeds indicate an inefficient coolant fan and the high ac pressures indicate that the condenser fan also is not operational
if it has a viscous fan hub , replace the fan hub
if it has electric fans check / the fans, fan relay , fuses , coolant temp sensor
May 07, 2017 | 2008 Ford Expedition El
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
The fan on my 96 acura tl comes after i cut the car off and runs loudly
The fan on a 1996 Acura RL will normally run for a short period after the engine is shut off if the temperature sensor determines the engine is too hot. However, if it is running constantly and not shutting off after you shut off your engine, then you will need to replace the fan relay. It is most likely stuck in a closed position. If your fan does shut off after running for a period of time when you shut off the engine but you have a noisy fan, then most likey the fan bearings are wearing out and it is more cost-effective to replace the whole fan. Thanks for using Fixya.
Aug 23, 2010 | 1996 Acura RL
My gateway m520x will run shutt down
Sorry you are having trouble. Laptops run a little hot but I think you are right about the overheating. The cheapest fix is to get an underneath cooler from somewhere like Best Buy. They sell for around $20. To really fix the problem will require finding out why it is getting hot. Usually this is a program that is "hogging" the processor's time. There are programs available that will make your fans run faster and processor run cooler. Some are free. Some cost a lot. If the fan has stopped or slowed it needs to be replaced. If you are very patient you can attempt to replace it yourself but be aware many a laptop has died as a result of being opened improperly. My advice is take to a shop if under cooler does not help.
I hope this helps
Apr 04, 2010 | Gateway M520X PC Notebook
Broken fan on compaq
don't keep running it until you replace the fan. Look for one on ebay or around the web. It is shutting down because of heat. A $20 fan could cost you your whole laptop if you keep running it.
Jun 03, 2009 | HP Compaq Presario CQ50-110US Laptop
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Exhaust fan
Is the light on?
Things that it could be.
Could be a door switch.
Or it could be a stuck fan relay
Or worst odf all it could be a bad Timmer Keypad board. Not worth fixing because they cost to much.
Jan 14, 2009 | GE JVM1542 Microwave Oven
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active Smart® E522BR...
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Slow, overheating, shuts itself off
sounds like your internal fans are taking early retirement, from all the symptoms..like running a car with no oil, you don't want to run a dell desktop without internal cooling..need to replace that fan..not too hard, actually.
May 04, 2008 | Dell XPS 200 PC Desktop
eMachines T5048  PC Desktop Logo
42 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
