Question about Cobra 200 GTL DX 4-Channels Base CB Radio
How to replace the on/off voulume switch?
I need help in knowing how to remove the bezel to get to the on/off switch.
Hello. I appreciate the help, Mechanic. I have had the covers off and what I am seeing is some small circuit boards that also contain the on/off switch that I want to remove. I am not sure if I want to proceed any farther. Thanks, Bigloaderman.
Posted on Feb 21, 2008
  • 204 Answers
Big, hi; I'll try to help out. I haven't had that model radio totally apart but on most radios, if you remove the top and bottom cover, on the sides you should see 2 screws per side that holds the chrome bezel to the chassis of the radio. Be careful removing the knobs so you don't destroy a pot in the process. Hope this helps you out, let us know,, Mechanic
Posted on Feb 20, 2008
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
How do I remove the driver side door panel on a 1994 Lincoln Mark VIII
Remove mirror mount cover assembly.
Remove inside door handle cup (22634).
Remove door lock control bezel.
Remove window control bezel.
Remove interior lamp lens.
Remove screw from interior lamp assembly body.
Remove screw from window control bezel opening.
Disconnect mirror, lock switches and memory seat on driver side from bezels and wire harness.
Disconnect window switches from window bezel and wire harness.
Lift front door trim panel (23942) vertically, out of weatherstrip and over lock rod.
Disconnect interior lamp (13776) from wire harness.
Remove front and rear door trim retention hooks into door inner panel.
To install, reverse Removal procedure, paying special attention when inserting inner door trim into weatherstrip. Rock inner door trim into weatherstrip and push downward until lower trim belt character ditch lines up with score mark on inner door panel.
Aug 16, 2014 | 1994 Lincoln Mark VIII
Need to find out how to change the turn signal/headlight switch on a 2001 Dodge Neon
dissconnect negitive battery terminal, open dirvers and passenger doors.remove dash end caps then use a pry stick or screwdriver and pry out left and right A pillar trim panels. next is to remove the bezel, lift up on the outter bottom edges of top bezel and along rearward edge of top cover top disengage clips, pull top cover rearward intil pins disengage from instrument panel and then remove from dash, next is to remove the cluster bezel and then the top and bottom steering column covers, the next step is to remove the screws holding the switch. then the connectors to switch.lift switch straight up and remove. to install reverse removal procedure. heres a diagram to help you understand the covers and bezels locations. hope this helps good day.johnjohn2_135.gif
Jun 25, 2011 | Dodge Neon Cars & Trucks
The headlights doesn't turn on. already change bulbs.
Your headlight switch needs to be replaced. Here's the section from the maintenance manual.
Headlight Switch REMOVAL & INSTALLATION
1996 Dakota
  1. Disconnect the negative battery cable.
  2. Remove the steering column cover and remove the instrument panel bezel. Two screws are hidden behind the steering column cover.
  3. Remove the screws from the headlight switch bezel, pull the assembly out and disconnect the wiring.
  4. Remove the nut retaining the bezel to the bracket. Depress the spring button on the right side of the switch and remove the headlight switch knob and stem.
  5. Remove the spanner nut and remove the switch.
  6. The installation is the reverse of the removal procedure.
Feb 01, 2011 | 1996 Dodge Dakota
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Need to replace side mirror
this is an easy job, alot of these you can pop the cover behind mirror and get the the plug and the bolts that hold the mirror. if not then remove the left top of panel just pull away from the door to get enough room to reach the plug or one of the bolts, if you what to remove the complete panel then remove the door reflector theres a screw behind that remove it, then flathead screw driver use to remove rear truck release bezel and dissconnect switch. next remove lower switch screws and bezel, then push door switch bezel up with screw driver and discconnect know gentle pull on panel to release hold on clips, these clips pop on and off. hope this helps.
Sep 14, 2010 | 2000 Oldsmobile Alero
How do I replace dimmer switch on 2001 Tahoe?
Removal & Installation (If dimmer is on headlamp switch area) To Remove:
Instrument Cluster Bezel removal chevy_sub15_02-04_instrum_clust_bezel_rem.gif
  1. Remove or disconnect the following:
    • The instrument cluster bezel
      1. Unsnap the switch from the housing
    • The electrical connectors Headlight switch removal chevy_sub15_02-04_headlight_switch_rem.gif
    • The switch
To Install:
  1. Install or connect the following:
    • The headlamp switch by snapping the headlamps switch into place
    • The bezel to the instrument panel
  2. Operate the headlights to check performance
Jul 16, 2010 | 2002 Chevrolet Tahoe
How do i take a shure ur2 apart to replace the switch?
There is a bezel around the switch. You'll need to remove the bezel and then the switch will fall off in your hand. At that point, you can remove the dome cover that covers the antenna. If you need to access the circuit boards, you'll need to remove the C-clip at the top of the transmitter and slide the boards out the top.
May 15, 2010 | Shure U2 / 58 with SM-58 Professional...
I need to replace the cigarette lighter unit and don't know how to take the dash apart
turn ignition switch to on ,shift trans into neutral,i'm assuming this is a baja,remove 2 screws under lid of center console cover lift this piece out of the way now remove bezel surrounding shifter,remove ashtray,above ashtray are 2 screws holding ashtray frame in place remove those now bezel surrounding radio can be removed and now you can remove cigar lighter good luck
Aug 19, 2009 | 2004 Subaru Baja
I recently bought a 2002 Pontiac Sunfire SE for my grand daughter as a High School graduation gift. Now the power windows won't go up or down. What could cause this problem? Hoping it is something simple...
This is One with the Power Window SWITCH in the CENTER Console they Often Get Liquids SPILLED on them Causing them to Fail, I Would First Check for 12volts @ the Switch with KEY ON. With a Sure 12volts Going IN the Switch Check for 12 Volt going OUT, If Switch IS BAD there Will be NO 12volts Coming OUT With this Go on to Switch Replacement
REMOVAL PROCEDURE
  1. Use a flat-bladed tool in order to remove the power window switch bezel (1) from the console.
  2. Remove the electrical connection from the power window switch (2).
  3. With a flat-bladed tool release the power window switch (2) tabs, and remove the switch from the power window bezel (1) retainers.
INSTALLATION PROCEDURE \
  1. Install the power window switch (2) into the power window switch bezel (1) until fully seated.
  2. Connect the electrical connector to the power window switch (2).
  3. Install the power window switch bezel (1) to the floor console.
((((>>>All of this is Assuming that All FUSES Related to And RELAYS Related to Windows Have Been Deemed GOOD & Funktional<<<<)))
If Further HELP / SUPPORT / INSTRUCTIONS Are needed P L E A S E Dont RULE me Out as I have the Answers, Just Try to be as Spisific as Possible and I will be More than HAPPY to Help you With your Needs of Auto Repair
Jun 15, 2009 | 2002 Pontiac Sunfire
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
59 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
