Question about HP Compaq Evo n610c Notebook
Battery totally exhausted. Direct power line is not working. Is there any relation between battery exhaustion and non-operation of direct power line? Whether installation of a new battery will solve the problem?
  • 109 Answers
Step 1 - Disable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list. 2. Click the Screen Saver tab and then click the Power button. 3. Under Power schemes, select Always On in the drop down menu. 4. Under Settings for Always On power scheme, select Never in each of the drop down menus. 5. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Step 2 - Fully charge the battery
Connect the AC adapter to the notebook.
Charge the battery until the Windows battery meter is at 100%.
Step 3 - Fully discharge the battery
Remove the AC adapter. Keep the notebook on until the battery has completely drained and the notebook automatically turns off. Connect the AC adapter to the notebook. Keep the AC adapter connected to the notebook until the battery has completely charged.
Step 4 - Enable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list. Click the Screen Saver tab and then click the Power button. Under Power schemes, select Portable/Laptop in the drop down menu. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Posted on Feb 04, 2010
Won't start, won't crank
have you crossed the solenoid terminals and checked the starter for operation? may have the battery cable burnt thru to ground by the exhaust side of the motor..it happens if the cable is up against the block..
Dec 26, 2013 | 2002 Ford Mustang
Golf Cart (Gas Powered) Stereo Installation
What I did was to buy a good blue tooth speaker and connect to my cell phone. 3 hrs on the golf course and 10% of the cell battery
Jul 06, 2017 | Cars & Trucks
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I replaced the spark plugs & spark plug wires with new & noticed the wire was totally melted on the left side of the engine (if you are standing in front of the car) right next to the exhaust...
Sounds like the wire was touching the exhaust manifold and was melted by the heat. There is usually a plastic thing that you clamp the wires into that keeps them from touching the exhaust manifold.
If theres not one of those things on your car, then use a zip tie or a piece of wire to tie the spark plug wire away from the exhaust manifold onto something above the wire on the cylinder head, throttle cable or something like that.
Sep 11, 2011 | 1994 Pontiac Firebird
2006 ford f-350. seemed like batteries dying for two weeks. then, it starting bucking and choking with black smoke out of exhaust. finally wouldn't start at all. replaced both batteries. still...
Well then... Jbsdoo,
You will need to immediately get it down to an EXHAUST shop that can do a COMPLIMENTRY diagnostic read...
or Exhaust back-pressure test...
Very likely your catalytic converter (or muffler
has blocked your engine and is suffocating it.
Avoid the common pitfall of REPLACING the
OXYGEN SENSORS... They are only REPORTING
the news...
Replacing your THERMOMETER if you are running
a FEVER would not help... Right...??
Check out YOUR COSTS on rockauto...
2006 FORD 350 SUPER DUTY 5 4L V8 Catalytic Converter RockAuto
Make sure you know your EMISSION LAWS...
You would hate to pay double just because you bought an ******* exhaust system
(No sympathy from California)...
EPA means nothing .. to C.A.R.B. compliance
(do it right)
More Information for WALKER 81972
Non C.A.R.B. (info only)
Amazon com MagnaFlow 93103 Direct Fit Catalytic Converter Non CARB...
Hope this helps...
Carnac the Magnificent
Aug 19, 2017 | 2005 Ford F 350 Super Duty
How to replace battery safety 1st digital thermometer model# 10428
According to the 10428 manual from Safety 1st:
"When the battery is exhausted. Dispose of the thermometer as the battery is non-replaceable. Be aware of any local regulations concerning disposal of this product. The battery cover
is sonic-welded to the main housing of the thermometer, the battery is well sealed inside the thermometer to reduce the risk
of being swallowed by children."
Jul 14, 2010 | Safety 1st Baby Care
Nikon L100 shows battery exhausted error message after installing new batteries. Unable to perform any operations on camera
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Jan 24, 2010 | Nikon COOLPIX L100 Digital Camera
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
My toyostove is making the room stinks(burned dieseal ) smell. What is causing this?
Something to check would be the exhaust vent for leaking. We just replaced our old Monitor 40 because it was making some terrible exhaust smells in our house and it turned out their was a crack on the exhaust line just where it enters the stove. May be worth looking into. They are a lot cheaper than a whole unit!
Nov 30, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
HP Compaq Evo n610c Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
