Music Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken foot pedal spring on a Baldwin Piano Pro
  • Anonymous Mar 27, 2014
    349685- year manufactured?
Fred Yearian
Level 3:
  • Music Master 5,603 Answers
  • Posted on Feb 01, 2010
Fred Yearian
Music Master
Level 3:
Answers
5603
Questions
Helped
2247484
Points
16162
Depending on the type of spring you can make your own.
For COIL springs, you can find suiable ones at ACE hardware and be creaitve... If it is too long, shorten it with grinding and reforming the ends. Find one that is about the right diameter and stretch tension.
Flat springs ar harder to fix... we use to get old clock springs and use the spring steel from them to fashion flat springs... You can often find springy falt springs in toys for children...
Finding original stuff is hard so one just has to be creative and it will give you a feeling of enpowerment when you succeed!
Baldwin Piano Pro-when it is turned on, a few lights come on but no sound.
It's possible that the internal components of the piano may have been damaged during storage or transport, causing the lack of sound. It may be best to have a professional technician take a look at the piano to diagnose and fix any issues.
As for the manual, you can try contacting Baldwin or searching online for a downloadable version. You may also be able to find a manual for a similar model that has similar features and functions.
Jul 25, 2022 • The Music
Baldwin Piano Pro an old electric piano, all lights flash, intermittent ability to play, then no sound when keys are played. I do not have a manual, what can I do???
Sounds like the power supply needs repair. Often the capacitors are leaking (electronically) and they cause the equipment to not work properly.
1helpful
2answers
I was wondering what the age of our baldwin piano serial #399572 is. thank you for any help
You did not state model, Check the attached links,for your model.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pianoworld.com/baldwin.htm
Free Piano Age Research
Baldwin Piano Age
Baldwin Pianos Company History Serial Number Search
Mar 10, 2016 • Music
What is the year this Piano was made? Baldwin grand- Model Bi serial 301587
Made between 1940-1946
http://www.total-piano-care.com/baldwin-pianos.html
Mar 20, 2015 • Music
What year was my Baldwin Acrosonic piano built? Serial number is 337856. Thanks
Your piano was made in 1946. Here's a link to the age/serial number list
How Old Baldwin Piano World
Feb 11, 2015 • Music
My pedal is not sustaining - it is plugged in at the pedal outlet, not sure what else to look for?
The first question is has it ever worked? If this is new, the connector of the pedals is a mini DIN type which is REAL hard to get seated properly. Often something blocks it from seating fully. Remove the plug and with a bright light inspect the pins... they are EASILY broken off. Aligning the connector carefully and making sure it seats is important. This piano also has a foot under the pedals to screw down against the floor but that isn't wht cause the pedals to not work.
1helpful
I have a Baldwin Piano Pro, electric that I received used. When it is turned on, I get a constant, load thrumming noise that will not change no matter the volume level. When you hit the keys, they all...
There are two possibilities that come to mind without being able to examine it personally. One is a filter capacitor in the power supply to the amplifier section is starting to fail and is not filtering the a.c. Two and more possible is the damper pedal or the sustain pedal have failed and you are hearing more than one note trying to sustain. Anyways you will have to have a technician service it.
Apr 10, 2010 • Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
