Question about Dishwashers
GE Quietpower 3 Dishwasher does not stop running when door is open. I'm really tired of getting splashed in the face because I forgot a plate. *head desk*
  • 619 Answers
Haha. Sorry but happened to me once. The door switch has gone bad. Get a new door switch and you'll be fine.
Posted on Jan 31, 2010
GE Dishwasher - loud rumbling/growling noice!
If I am not mistaken this dishwasher has a Clean out at the bottom of the machine that can open .This is here to catch stuff like broken glass and things like that. It has a little fan like blades that act to chop up food that is to big to go down the outlet hose. also look under the machine if you can ,but in most cases you must remove 4 screws to get the bottom kick plate off, Also check all the spinning arms to make sure they are turning correctly. hope this helps
May 02, 2012 | GE Dishwashers
My ge quietpower 1 will not shutoff when door is opened
There is an interrupt switch generally located in the door as part of the latching mechanism that stops the washer, yours is probably either shorted or has become damaged is some way.
Dec 16, 2011 | GE Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
