Question about Lite On LiteOn 150W LPX Power Supply (190306) Power Supply
Cannot locate the fuse in the liteon power supply
Cannot locate the fuse in the liteon 300W power supply model no. ps-5301-08HA. is it in a clip and easy to replace, or soldered onto board?
    Genius:
  • 1,027 Answers
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Posted on Jan 31, 2010
Blows fuse
If your Liteon 32276 power supply board is causing blown fuses, there are a number of things to try.
Try plugging into a different outlet in your house to see if the result is the same.If the result is the same, you may need to replace your liteon 32276 power supply board as it may be defective.
Apr 16, 2012 | Computers & Internet
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Jun 26, 2009 | Lite On (PA41519B1) 150-Watt Power Supply
Won't turn on - PS light on but no PS fan
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
May 07, 2009 | Computers & Internet
Power Supply Bestec ATX-250-12E Rev.P6
Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
SMPS for compaq proliant 1600 server
my email techdcs@yahoo.co.in I can provide a replacement for the same power supply , it's a brand new one
Apr 26, 2008 | Compaq mATX ATX12V 300w Power Supply Part...
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
See all Lite On LiteOn 150W LPX Power Supply (190306) Questions
Lite On LiteOn 150W LPX Power Supply (190306) Power Supply Logo
1,764 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
