Question about Canon CLC 1120 Color Copier
CANON CLC 1100 ERROR CODE E079 CAN YUO HELP ME?
THE MACHINE CANON HAVE ERROR CODE
E079 AND SUBCODE 0000
THANKS.
  • Canon Master
  • 19,396 Answers
E079 is in effect a drum fault. If you tell me your location I will find the price for a drumkit in your area, in UK should be between 50 and 80 punds
Posted on Feb 18, 2008
    Scholar:
  • 110 Answers
Hiya!
Not a lot of information on the codes for that fax, but it appears that E079 means drum cleaning unit. Typically with these machines, the cost to service is greater than the cost to replace, so my recommendation would be to save the headache and pick up a new fax/mfc.
  • 689 Answers
Have you tried to reset? maybe you can reset first meanwhile I will be looking for further solution
  • ExpressFiX
    ExpressFiX Feb 18, 2008
    you may also clean OPC drum area, You may check if the OPC drum moves
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon irc2105 Error code E216-0000
hi i had a problem error code E810-0302 can you help
Mar 01, 2010 | Canon CLC 4000 Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
Error E079 Am using in canon 1180 Printer
E079 is the transfer lift clutch unit int the rear of the copier. You have to remove the unit and look for a broken cam & or pin that goes in the cam and clean both sensors and flags in that unit and make sure it is sping freely. The unit ingages the transfer cleaning unit. Good Luck.
Nov 06, 2008 | Canon CLC 1120 Color Copier
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
Canon error E079
E079 = tranfer drum cleaner does not engage or return to home position (ps9) first check the sensor ps9 and check the moter that operates the cam that engages the TRANSFER DRUM CLEANER. if you nead to know more please get back to me i am in the uk 00447764303923
Thank You
Feb 18, 2008 | Canon CLC 1120 Color Copier
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
232 people viewed this question
old marine
old marine
