Question about ASUS Eee PC 1000H Laptop
Plugged in AC adapter, Eee PC 1005HA will not turn on. Made sure connector is solidly in. Computer has been idle for some weeks. Purchased computer last August, and it was working fine in December.
    Guru:
  • 689 Answers
Check fuse on the plug first
Posted on Sep 05, 2010
I am unable to use the ac adapter. the connector has broken off inside the adapter plug.
firstly check the power supply is working, if it is not, replace it with a new one. the next thing would be to replace the socket on the notebook, as this may be broken. it would have to have the solder connections checked or replaced with a new one.
i hope this was useful
Feb 28, 2013 | Asus Notebooks Asus Eee PC T101MT-BU37-BK...
ASUS AC/DC adapter not working
Replace it, cheaper in the long run.
Mar 29, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When you put the charger they have light and no power
Please remove and clean the Battery terminals of the Notebook, make sure that the output pin of the AC Adapter is properly connected to the notebook. The fault might be either with the output pin of the AC Adapter or Input DC socket of the Notebook.
Mar 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
My laptop keyboard is lock or not typing at all ..is a eee pc 900
hi good day! just a piece of advice and it might work, try to do power drain which will remove any static on your computer.
try to power off the computer, make sure that it is completely turned off,
try to remove the ac adapter and the battery as well and anything that is plugged in on to your comp. Then press and hold the power button for 15, seconds after that put the battery back and the ac adapter and then try to power on the computer.. hope this will work goodluck!
Jun 02, 2010 | ASUS Computers & Internet
No power/charge
Check that the battery is properly installed. Check the AC Adapter for power. Otherwise take the machine back to the seller. It is still under warranty.
Feb 03, 2010 | ASUS Eee PC 1000H Laptop
Asus eee 900ah Plugged in a charger and battery is full. Now wont boot up. Any ideas?
I am not sure what the exact issue happened to ypur computer, if you are not able to turn on the computer then remove the battery and AC adapter from the laptop, not press and hold the power button for 20 sec( No batteery and Adapter), now connect the power cable back to laptop and then try to turn on the computer, still not able to turn on the computer then you consult with local tech or with wantty
Nov 20, 2009 | ASUS Eee 900 Netbook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
ASUS Eee PC 1000H Laptop Logo
380 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
