Question about Compaq iPAQ H3850 Pocket PC
Secure Digital Card for iPAQ 3850
Is there a limit to the size of card that can be installed and work properly; I see ones available from 128mb to 2gb and larger.
1 gb
Posted on Nov 01, 2008
IPAQ hw6915 memory card
maximum limit recomended buy HP is 2GB,
Jun 21, 2012 | HP Cell Phones
What size memory card can I used for my easy share c330.
The C330 uses SD and MMC cards. SD cards are limited to 2GB in size, so that's the upper limit. Cards bigger than 2GB are technically SDHC cards. They will fit into the slot but will not work.
May 20, 2010 | Kodak EasyShare C330 Digital Camera
My Sharp VE-CG40U Digital camera has a 128MB SD card, what is the maximum size card I can use in this camera. I have tried and 2GB card and that did not work.
The manual doesn't specify a size range for SD cards in your camera, but I've seen 2GB cards offered on line for it. Make sure that the write protect switch on your new card is in the UNLOCKED position and that the card has been formatted for your camera.
Dec 27, 2009 | Sharp VE-CG40U Digital Camera
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Size of sd card
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
Feb 25, 2008 | Vivitar ViviCam 5299 Digital Camera
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
What size of flash memory card do you recommend me using with my PENTAX digital camera?
The answer depends on your personal needs and your budget. Memory cards are available in many sizes 8MB, 16MB, 32MB, 64MB, 128MB, 256MB and 512MB. The larger the card size, the more storage space and the greater the cost. One recommendation is to select a card that allows you to take images without having to worry about changing cards or downloading images very often (one of the advantages of digital photography). Among the most popular are those in 64MB, 128MB or 256MB sizes. You may want to purchase a second card to use as a back-up or replacement card that can be used if you run out of space on the first card or to use when the first card is unavailable (you may be downloading or printing images from the first card.)
Aug 30, 2005 | Pentax *ist D Digital Camera
Compaq iPAQ H3850 Pocket PC Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
