Question about RCA 20F420T 20" TV
I enabled the FPA lock on my RCA 20f511T and it shut off. Now I can't turn it on with the panel on the TV or the remote.
  • 2 more comments
  • bchat612 Jan 31, 2010
    I tried that earlier today. I'll try it again. I unplugged it for more than 10 minutes. I'll try it again and then accet your answer if/when it works. Thanks.
  • bchat612 Feb 03, 2010
    None of that worked. Thanks for trying.
    Unplugged it over night and that didn't work either. Thanks anyway.
    I've tried unplugging the power overnight, holding 0 on the remote and menu on the screen, menu on the remote and volume down on the tv etc. Please help.
Ive lost my rca remote and am usiing my cable remote.the fpa lock is on and i can,t get it off to play video dvd,s etc.anyone with a answer
Posted on Feb 26, 2010
  • 10,515 Answers
Most RCA and GE
TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OR try http://specs.retaildeck.com/CACHE/FILE7065.PDF
search for FPA and you'll find how to unlock it.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 01, 2010
  • 443 Answers
Disconnect the power cord from the outlet for AT LEAST 30 MINUTES, that should cause the TV to reset back to factory default settings, then you can start over with initial set up,etc, after you restore power to it.
Posted on Jan 31, 2010
Hi how to open fpa
The front panel lock can only be unlocked with the remote. Press Menu, then Ch+ or Ch - to select Preferences. Press Ok then use the Ch+ or Ch- buttons to highlight FPA (front panel) lock. Then use the Vol+ and Vol - buttons to select On or Off. Then press Menu repeatedly to exit the menu system. With the FPA lock disabled, you can turn it on from the front panel of the TV by pressing the Menu button. However, with the lock enabled, you can only power off the TV from the front panel.
Since the Input button is also only on the remote, if you look for a universal remote, choose one with both Menu and Input or Source functions. Then try all the RCA codes until you find one that makes all of the remote functions work. The original remote is: RCR130TA1 . A substitute remote that should match all of the functions is available here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=13004957447460 .
The manual for the RCA 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . If the direct link doesn't work, start here: http://support.ttetech.com/en-us/productdownloads.html . Select a 20" TV and then your model number in the drop down menus and press Go.
I hope this helps.
Mar 19, 2011 | RCA 20F420T 20" TV
Fpa lock is on yes I want it off
Hit the menu button and it will let you in to turn FPA off.
Jun 08, 2009 | RCA 20F511T TV
RCA FPA LOCK ON
Hit the menu button and turn FPA off.
Feb 16, 2009 | RCA 20F511T TV
FPA LOCK IS ON AND I HAVE NO REMOTE FOR THE TELEVISION,,, HOW CAN I FIX THIS?
You will need an RCA Remote or Universal (RCA) may work. Once the Front Panel Assy. is locked the TV will only Power on with a remote. Call an Authorized RCA warranty service center, and offer to leave a deposit for the use of the remote. Power the TV on with the remote. Press Menu on remote. Press CH- (down) button on remote to highlight "Preferences". Press OK button to open menu. Press CH-(down) button to highlight "FPA Lock". Press Vol.+ button to turn off FPA Lock.Press Menu button to return to Main Menu. Press Menu button again to clear On Screen Display.
Dec 23, 2008 | RCA 20F420T 20" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
FPA
How do u get the Fpa unlock cuz i just got cable
Jul 06, 2008 | RCA 20F511T TV
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
RCA FPA LOCK
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
Sep 02, 2007 | RCA 20F511T TV
FPA lock
rca fpa will not trun off plz help me trun it off
i nedd help plz
ty for your help
betty
Aug 15, 2007 | RCA 20F511T TV
RCA 20F420T 20" TV Logo
740 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
