Question about Acer Aspire 5500 5570-2609 Laptop
Help! i went to shut off my laptop and it said updating windows..but the power shut off.when i tried to pt it on this morning it won't let me. It brings me to this screen that states the problem but it doesnt do anything I dont know what to do!.I need help really fast!
  • gucci05 Feb 19, 2008
    hey ..wht i meant by that it turned off was that the power turned off because the battery was dead!...i tried turning it on but it still brings me to the same screen!..wht do i do! =)
    Problem Solver:
  • 15 Answers
You might have connected to interent and your windows updates are automatically downloaded. You need to install those updates. Actually it did not shut but power goes off may be it was on stand by mode. Now shut down (press Alt+F4) your laptop from menu. Choose Install Updates and Shut Down from the drop down list.
Now it will install updates and after completion it will automatically shut down your laptop. Hope it works
Posted on Feb 18, 2008
Hp dv7-4165dx caps lock blinking, not powering up
I had the same problem with my HP DV7-4165DX. Here is the solution, although it may sound crazy.
1. Lift open the screen.
2. Take a towel and wrap it around the base of the laptop so no air can escape from the fan.
3. Turn on the laptop and let it get hot for 15-30 minutes.
4. Turn off the laptop.
5. Remove towel and power it back on. The laptop should boot up and go into Windows. This is a temporary fix - once you power it down and let it cool off, it will not turn back on and you will have to repeat the process.
6. While in Windows, you need to update the BIOS to "2013-02-26 , VersionF.29, 4.16M" Here is the link to the application:
http://ftp.hp.com/pub/softpaq/sp61001-61500/sp61028.exe
7. Run the executable file.
8. The BIOS will ask you to shutdown.
9. When you power the computer back on it will run a program to update the BIOS.
Now, I tried this last night. I turned the computer off before I went to bed and it was cold in the morning. I hit the power button and it started right up. I shut it down and ten minutes later tried it again - it started right up. Hopefully you will have the same success I did.
Sep 28, 2013 | HP Computers & Internet
My acer 1 netbook wont start back up after trying to do updates
format your drive in which windows is loaded and then load windows a different drive (D or E or F etc) it will work and after re instalation windows disable windows update from control panel (control panel then system and security then windows update then turn automatic update on or off then select never check for update) and apply
Jun 18, 2012 | Acer Aspire Computers & Internet
Toshiba Tecra M10 hanging when windows is shutting down after an update
Are you sure you are not too fast or impatient for it. Sometimes after doing updates it might take awhile to get past the Windows is shutting down...
Give it some time and see what happens. If after 15 minutes it is still there, press and hold the Power Button until it shuts off then Reboot. Try shutting down again and see if it hangs.
May 14, 2012 | Computers & Internet
Toshiba laptop frozen pointer mouse
  • If you're having problems with Windows Update, make sure you're connected to the Internet, and then download and run the Windows Update Troubleshooter for your version of Windows.
  • Download troubleshooter for Windows 10
  • Download troubleshooter for Windows 7 and Windows 8
  • After the troubleshooter finishes, try running Windows Update again and install any available updates.
  • Or,
  • https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
  • Mar 15, 2017 | Computers & Internet
    My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
    Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
    Jun 20, 2011 | Dell Inspiron 1545 Notebook
    Laptop locked up this morning. Went to reboot, Irt
    Hi. Try to tap F8 during start and then try safe mode then reset it again. If this doesn't help try to clean you computer inside it looks like overheating problem.
    Oct 15, 2009 | Computers & Internet
    ACER Aspire 5100 powers down at will
    When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
    Apr 15, 2009 | Acer Aspire 5100 Notebook
    Cannot start up my laptop since in done an update
    Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
    Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
    HP screen problems
    Try removing the battery, plugging in the laptop and trying again. Else it appears to be a power supply issue.
    Jul 05, 2008 | Acer Aspire 5610-4648 Notebook
    Acer Laptop Vista service packs 1-3
    remove power supply nd battery, should allow you normal boot up.
    Jun 29, 2008 | Computers & Internet
    Acer Aspire 5500 5570-2609 Laptop Logo
    147 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
