Question about ASUS SKT-775 P5QL/EPU S/L 1333FSB (90MIB575G0EAY00Z) Motherboard
SATA drive takes too long to boot up
SATA drive takes too long to boot. Takes 75 seconds to find drive. but if I hook up my old IDE drive in addition to SATA drive it will boot up in 2-3 seconds.
  • ltkb Jan 31, 2010
    Sata drive is connected to first socket. When I first installed new motherboard I only had new SATA drive connected. Out of frustration I connected IDE drive to see if it would make a difference. If I disconnect IDE drive it goes back to 75 second boot up.
    Genius:
  • 1,027 Answers
Is the SATA drive connected to the first socket? Also, if the old IDE drive is not used, then disable their use in the bios - don't use the AUTO function.
Posted on Jan 31, 2010
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Oct 01, 2014 | Systemax Computers & Internet
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
I hook up the sata bridge adaptor and my computer is not reconizing the the hard drive is even there i can hook it up to ide and it works fine just wont work with the bridge
The bridge has a jumper I believe next to where the powerplug is. This jumper must be pulled out and put on the A-B NOT the A-C if youare going to use the IDE ribbon cable. Another trick is do not use the IDEcable (extra) that you may have with or below or above your other harddrivesince bios will always keep trying to go to your SATA drive even when youchange your primary drive with working operating system to slave and changeboot order....will just show on screen something like no boot disc. The easiestway without messing with the bios and drivers and all is this....move jumper toA-C then use one of the IDE cables that you have (you should have 2) of youCD-ROM. If you are using 2 CD-ROM's remove one and plug this IDE cable intoyour SATA bridge. The computer will now find new hardware. Then right clickthat new found drive when you click "My Computer" from"Start" and "Format" it, just to make sure everything is off thedrive even if new it will not hurt. Not sure if you want your SATA to be yourprimary drive but if you do,you now can use Acronis Ghost software or other tomirror your primary drive onto your new SATA. Once done take out or dissconnectyour primary drive and install your SATA into that slot or above or below yourprimary drive if you have available room in your tower then hook that IDE cableto your SATA and hook power. BAM.. your computer will now use the SATA to bootup and all is fine. Remember SATA does not have slave/master jumpers like IDEdrives. Now if anything happens to that SATA you still have you disconnectedprimary drive to fall back on. If your concerned about wanting 2 drives you maybe able to take your original primary drive and change that jumper from Masterto Slave.Since bios will default to your new SATA drive now and use that hasyour master and boot up from that drive. If you do not want to use yourSATA as your primary without installing an operating system or usingghost/mirror software then to make life easier just use the IDE cable from oneof the CD-ROM's or get an extension IDE cable that will reach since your SATAdrive is smaller and most likely will not neatly fit into the CD-ROM slots. Youcan use the extra slot if you have one above or below your primary drive yourusing now, then plug your CD-ROM IDE cable (with extension if needed to reach)into SATA and then you can now use the SATA to send files and anything else youwant to store in that drive. Hope this helps.
Dec 29, 2010 | Kingwin SATA to IDE Bridge Board (ADP06)...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
A1430N Moved my two working ide drive 250G over
Hello
Thank you for using
FixYa for your problem
IDE will try to boot first when pluged in, sata will not boot. I think there is a adjustment in the BIOS setting to have the SATA boot first
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Bought a Acer 9301 awsmi and its not switching
No, system will not stop working.
SATA and IDE drives have different connectors, so if motherboard is made to take SATA - it takes SATA, if IDE - then it takes IDE.
Also IDE drives are past. SATA drives are much better and works faster.
So there is nothing to worry about.
Mar 28, 2009 | Acer Computers & Internet
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
ASUS SKT-775 P5QL/EPU S/L 1333FSB (90MIB575G0EAY00Z) Motherboard Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
