Question about Behringer XM8500 Professional Microphone
I dropped my mic and now it doesn'r work. Wire connections inside are good. Is it shot?
    Champion:
  • 211 Answers
I think your element is broken.
You can take a ohmmeter and measure the resistance of the element.
If it's endless the lementwire is broken.
It could also be that the coil is stuck between the metal parts (like a loudspeaker).
Good luck,
Gerard
Posted on Jan 31, 2010
No sound
1st thing to try is a different XLR microphone cable. Sounds too simple, but sometimes it's the cable. If the mic has ever been dropped/damaged, OR has seen alot of saliva/spit from singing into it...it's possible the diaphragm has crapped out. At which point, get a new mic, because the SM-48 is not an expensive mic to replace with same.
Jan 06, 2013 | Shure SM48 Professional Microphone
My xbox 360 mic is acting up. I can talk to people but I can only hear them if the plug is twisted to a certain position
Sounds like a wire broke inside. That's why it only works when you have it in a certain position. Unless you are good at splicing wires, move the wire till you get it to work, and wrap it in that position, then don't move it at all. Good Luck.
Jul 01, 2012 | Eforcity HEADSET W/ MIC CONTROLLER FOR...
CB is in transmit mode with no mic connected
Got a short either at the mic socket or the keying circuit--try first to disconnect leads at the socket one at a time.
Jun 12, 2012 | Radio Communications
Dose'nt work
email the company you purchased from
Jun 18, 2011 | Shure SM58 Professional Microphone
Battery is brand new, connection is good at the battery. All fuses are good. Turn key on and nothing happens. We ran a wire from the postitive side screw on the fuse box to the pos lead off the battery and...
You've checked the connection from the fuse to the batterie but have you tried to bypass the keyswitch, it could be the switch doesn't connect inside or the key doesn't turn the switch inside.
Jun 11, 2011 | 1987 Suzuki GV 1400 Cavalcade GT
How do you replace the mic in my radio cant get the old one out
If you got a new mic open the radio from the back, there are 4 phillip screws on the back cover, remove the screws, then pull the back off, there is a rubber seal between the face and the cover, the seal is reusable, turn the radio face down, look at where the mic wire enters the face and there is a safety clip and a plillip screw that holds it in place, remove the screw, pull the clip and the mic wire is connected with a small 3 conductor quick-connect inside the radio. Then just replace the new mic wire and place the safety clip and screw back in place and re-connect the 3 conductor quick-connect, replace the cover and you're ready to use the radio. Good luck.
Jan 04, 2011 | Uniden Marine 25 Watt Radio With Noaa...
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Dropped my Nokia E90 phone and the mic stopped working. does the mic need to be replaced?
my friend in this phone they use a digital mic that can be easly damaged since you said that you dropped it surely its brkoken so yoou have to replace it in good service center.
Nov 05, 2009 | Nokia E90 Smartphone
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
Volume ccd-trv318 model
yes i believe the problem is the microphone in the camera, just open up unit find microphone disconect it and replace with exact mic from radio shack catalog...or try to find a mic from another electronic device of the same size ( fixed mine with a mic that was inside a cellphone headset wire.) hope this helps... but i am almost possitive your mic is shot from your syptoms
-Phil
Apr 12, 2009 | Sony Handycam CCD-TRV318 Camcorder
Behringer XM8500 Professional Microphone Logo
183 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
