Question about Vestax Vmc004 4-Channel DJ Mixer System
How do i replace faders for the vmc 004 - Vestax Vmc004 4-Channel DJ Mixer System
  • 102 Answers
Hi you will have to open the mixer, make sure the power cord is not plugged in. The fader screws in from the back and the wires may be soldered. so you will have to unsolder the wires and re solder them to the new fader and replace and screw new fader in. Close mixer ..
Posted on Jan 31, 2010
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
Jul 09, 2016 | Numark Music
Why won't my vestax vmc 002 turn on
Try replacing the fuse by one with same voltage and rating. Usually if you take a look at paperwork that came with the mixer it will show you which fuse you should use.
Jan 05, 2013 | Vestax Vmc - 002 Xl
How hard would it be to change a fader control on a peavey escort 2000
Changing faders USUALLY involves removing all panel hardware so that circuit board can be removed to get at the fader. It is often a LOT of work with a boit of hazards along the way.
If the control is noisy I want you to try something before replacing the fader. Get a can of CRC226 available at Home Depot in the Electrical department... about $2.70 for a can. Using the included plastic spout tube, squirt a bit into the center of the control where the knob is. Work it back and forth and then put a little more in and test if it is better or fixed.
NEVER use DeOxit or Blue Shower in faders!!!!! It removes the lube that is required in the fader.
Jan 04, 2011 | Peavey Escort 3000 Packaged PA Speaker...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Turntable Crackling
sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Feb 03, 2009 | Technics SL-1210 Turntable
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Pitch/Tempo control/fader problem
You can buy a contact cleaner spray and spray inside the fader while moving the fader from -10 to +10. If the problem is dust or dirt this will fix it. If the problem presists, then go ahead and get a fader replacement.It's easy to replace ;-) Regards. DiMiS Greece.
Aug 06, 2007 | Pioneer CDJ-500II CD Player
Vestax Vmc004 4-Channel DJ Mixer System Logo
165 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
