Question about Toshiba 36A40 36" TV
Toshiba TV has EDS control on the remote. Turns on for a short time and then right back off. the EDS screen overlays my real picture and is solid black with the real pic only showing about 1 inch around the sides. THe EDS seems to control a timer somehow but it is always set for 00:00 and doesn't change. Almost looks like a PIC in a PIC but that does not change it. the PIc in a PIC works fine. This never has happened before. the TV was bought in 1993.
5 Suggested Answers
SOURCE: no pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Posted on Nov 02, 2006
  • 163 Answers
SOURCE: Toshiba 27A30 that blows Fuse
hey this one was posted agust 6 do I geting crazy or what? agust 7 agust 6 the same day?
Posted on Aug 07, 2006
SOURCE: Sides of picture cut off on Toshiba 27D46
Check for dry capacitors on the tv board
Posted on May 16, 2009
johnnydiode
  • 647 Answers
SOURCE: the 36A50 t.v.that i owned for 8yrs.started with
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? or AN?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Posted on Nov 06, 2009
Cf35e50 toshiba tv
turn off the close caption in the settings.
Sep 30, 2012 | Toshiba 36A40 36" TV
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
How to overlay picture in D40x camera
Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
Mar 05, 2010 | Nikon D40x Digital Camera
Need codes
The Toshiba TV codes for an Innovage Jumbo Remote are: 013, 049, 089, 105, 109, 117, 118, 120, 159, & 178.
If they don't work, you can try the auto-search function to see if aother brands' codes work:
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
I have a Toshiba 19 inch TV/DVD combo and would like to use the Remote with it. What do I need to do? Thanks
Here you go. This will work with most all universal remote controls. If you don't have the code do the following: This is mainly for the Brookstone.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 19, 2009 | Brookstone 538744 Remote Control
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
Nov 29, 2007 | GE JASRM24912 Remote Control
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
Toshiba 36A40 36" TV Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
