Question about Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator
Am unable to reset refrigerator temperature. currently at 60 degrees
  • 619 Answers
Do you have a lot of frost on the back wall of the freezer section. If you do you have a defrost problem. If you have no response from your controls the control board is part number W10207861 about 165.00. You want to be sure before spending for a board it may not need. Hope this helps.
Posted on Jan 31, 2010
Freezer works refrigerator portion does nt
If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Regards.
Aug 15, 2011 | Refrigerators
Fridge is running but not getting cold. Line underneath feels very cold but air coming in fridge is not cold. Fan under the freezer and fridge is running.
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to a bad defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Refrigerators
Refrigerator is not cold. Freezer works OK
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
Good luck.
Jul 11, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Hi, my refrig is JennAir JFC2087HRS, top refrigirator is not cool and there are lots of frosts at the back of bottom freezer, how can I deal with it ? short-term by unplug and open the freezer to...
If refrigerator is not cooling, it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
Good luck.
Apr 07, 2011 | Jenn-Air JFC2087HRS Side by Side...
Fridge freezer - freezer working but fridge not. red warm light is on
Good luck.
Mar 30, 2011 | Refrigerators
MY intergrated NEFF fridge is not getting cold. I have power (as the light comes on) but it does not seem to be chilling-what could this be?
Good luck.
Mar 30, 2011 | Neff Refrigerators
Freezer works but not refrigerater why?
Good luck.
Mar 23, 2011 | GE Refrigerators
Frezer works but fridge does not get cold
If refrigerator is not cooling properly, it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
Good luck.
Mar 22, 2011 | Frigidaire Refrigerators
Freezer cold but refrigerator is not
Good luck.
Mar 22, 2011 | GE Profile Stainless Bottom-Freezer...
Open Questions:
Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator Logo
137 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
